Spun Rod Bearing Question. PLEASE HELP!!
so im pretty sure i spun a rod bearing in my sr. it drive fine and sounds fine at idle but if you pop the hood and pull the throttle cable you can hear a horrible noise around 3k but then it stops if you let it go back down to idle. i know there are different grades of rod bearings, i read something about you have to get the numbers off the crank that will tell you which ones to get but i was wondering if all s13 sr's are the same? if so do any of you guys know which grade i need to get? please help me out, im trying to get this fixed asap. thanks!
