Old 06-24-2008, 06:51 PM   #1
Boosted240Guy
Boosted240Guy's Avatar
Boosted240Guy is an unknown quantity at this point
Oil Filter problem Help!!!
Hey guys I need some help! If your gonna flame then just dont bother posting anything. heres the deal I have a oil filter on my sr20 under the stock intake manifold that will not budge. I have tried absolutly everything....I have broke 2 shitty oil cap wrenches on it. Bought the vice grip oil wrench. I have tried the leather belt trick from the bay and the bottom end. i have tried the sandpaper trick and I'm a pretty big guy so I've put a lot into trying to get it off. I have also tried the screwdriver through the filter but I can't get enough leverage to get it to budge. The guy who had the car before me like an idiot tourqed the fucker on as tight as he could....Any suggestions please help!!!!!!
Boosted240Guy is offline   Reply With Quote
Old 06-24-2008, 07:01 PM   #2
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
get the oil filter remover thing that is triangle shapped and it goes over the top. the hard you turn it the more it grabs the filter. that should work. if not keep trying everything else.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 06-24-2008, 07:02 PM   #3
loveskylines
loveskylines's Avatar
loveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura aboutloveskylines has a spectacular aura about
buy a new motor! j/k
try to cool the filter itself..it should shrink it enough to come off... or just slowly break it up... thats a lot messier but it sounds like he didnt lube the seal prior to putting it on, so the gasket may be melted to the block..try taking some fine metal cable.. kinda like floss to cut/break the seal from the rubber gasket to the block...
take a break from it and look at it in 15 mins... sometimes i get so wrapped up in doing something i miss the obvious.
gl
No MORE S13!!
SC300!!!
loveskylines is offline   Reply With Quote
Old 06-24-2008, 07:07 PM   #4
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Umm..I wouldnt recommend breaking the filter. thats a big no no.^
That's the last thing you want is metal shards falling inside your oil filter tube...
Have you tried to get an oil filter cup specifically designed to fit snug onto your filter? You should be able to connect it to a 3/8th's ratchet and screw it out.
If the filter bandwrenches are slipping...try getting a rag and fitting it inside the band while trying to budge it..
If you are using filter pliers...Use the ones that can grab snug around the entire filter...this helps for non slippage. Pinch in and turn.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 06-24-2008, 07:13 PM   #5
derk
derk is making a name for him/her selfderk is making a name for him/her self
use this kind of oil filter tool.
derk is offline   Reply With Quote
Old 06-24-2008, 07:16 PM   #6
Temple240
Temple240's Avatar
Temple240 is just really niceTemple240 is just really niceTemple240 is just really niceTemple240 is just really niceTemple240 is just really niceTemple240 is just really niceTemple240 is just really niceTemple240 is just really niceTemple240 is just really nice
As a last resort stick a screw driver through the bottom of the filter (make sure you stay clear of the filler) and use it to turn the filter. Have you tried taking it off using latex gloves?
Temple240 is offline   Reply With Quote
Old 06-24-2008, 07:28 PM   #7
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
Are you turning it the right way?
undesiredshoe is offline   Reply With Quote
Old 06-24-2008, 08:08 PM   #8
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
rofl +1
yeah, don't forget to turn it the right way.....
just go at it like a mofo, SR has filter placement like ass..
just go at it.. you'll get it off.
My iTrader rating!
babowc is offline   Reply With Quote
Old 06-24-2008, 08:11 PM   #9
downshift_sideways
No Limit Soldier.
Use this kind of tool.
Old 06-24-2008, 08:40 PM   #10
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
start working out. you have weak woman hands!!!
naw, i hear you....my shit wouldn't budge either (s13 sr20).
i just really used brute force, i got mine out from the top. i just kept trying in sets then resting, like a workout.
get some brake cleaner, and spray the shit out of it cuz you probably got it all greasy.
you really just have to get the right grip on it. get some of those mechanics gloves too. they didn't do it for me, i actually get mine off bare handed.
my fucking hand was killing me for two days after that...
at the end of the summer, i'm pulling my engine to do heater hoses and oil filter relocation.
clark is offline   Reply With Quote
Old 06-24-2008, 08:44 PM   #11
iHeartTheTouge
iHeartTheTouge's Avatar
iHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfection
/threadmsglngth
Slide 'n Hide
-'72 240z LS1 project
iHeartTheTouge is offline   Reply With Quote
Old 06-24-2008, 08:51 PM   #12
downshift_sideways
No Limit Soldier.
I agree I use to work at oil stations.
our cars along with miata's and rx7's are a bitch to get the filters out.
Try getting it from the top, and maneuvering your arms next to the fuse box.
Good luck!
Old 06-24-2008, 10:38 PM   #13
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
exact same thing ahppened to me...my sr's filter just wouldnt budge, I tried everything...eventually I just ended up taking off the alternator and getting a adjustable filter wrench thing on it. this allowed for alot more room and was able to get good leverage. good luck
njd07 is offline   Reply With Quote
Old 06-24-2008, 10:59 PM   #14
Gnnr
Gnnr's Avatar
When that dosen't work, I use this
Works everytime, the teeth rip right into the oil filter and it comes out like a squished soda can. hehe
Gnnr is offline   Reply With Quote
Old 06-24-2008, 11:06 PM   #15
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Hes already tried using a screwdriver.Also how would a laxtex glove help? All the tricks he's tried grip a hell of a lot better then going barehand with latex gloves. Whats the sandpaper trick? Im assuming your roughing up the surface of the oilfilter for better grip? Best advice i can give is to use the triangle claw tool. I use it at work all the time and it makes taking filters off alot easier. Gl
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 06-24-2008, 11:21 PM   #16
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
the same thing happened to me and i just found it faster to take the lower and upper intake manifolds off, its real easy that way
n240sxfnatic is offline   Reply With Quote
Old 06-26-2008, 12:44 AM   #17
Boosted240Guy
Hey Thanks guys for all the advice....I ended up getting it off....ha I used it like a work out...in sets I mean. I gave up yesterday and let it sit overnight and then this morning I went and got the last tool I hadn't tried its like a cup almost but only has two sides and pretty much crushes the thing...it was just small enough to fit perfect and i put the wrench in I gave that fucker a good twist to the left and it popped off the oil inside the filter was chunky, good thing I didn't drive it much. Lets just say I lubed the fuck out of the seal on the new filter and put fresh Royal purple in...Thanks again guys
Old 06-26-2008, 09:50 AM   #18
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
For next time, you also might consider removing your intake manifold support brace, right near the filter. It frees up some space and gives you more room to work when you're trying to get a good grip on the filter.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 06-26-2008, 04:07 PM   #19
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I always just twist that bitch bare handed. I end up coming out with cuts all over my hands, but its the only way I've been able to do it.
Old 06-26-2008, 05:03 PM   #20
downshift_sideways
No Limit Soldier.
Only pansies have to take off a part in order to get your oil filter out.
You'd be surprised how shitty these filter wrench's slip.
Old 06-26-2008, 07:33 PM   #21
SHIFT_*grind*
Or maybe it's easier than buying shitty cap wrenches that break?
Old 06-26-2008, 08:01 PM   #22
240=180
240=180's Avatar
240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about
not if you use the metal ones....
240=180 is offline   Reply With Quote
Old 06-26-2008, 08:09 PM   #23
projectRDM
projectRDM's Avatar
I've broken a half dozen metal cap type wrenches. The center portion where the ratchet fits always breaks loose.
+1 for removing the support brackets. Useless shit, in the way.
FORMERLY R240NA
