Old 02-07-2009, 11:25 PM   #1
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
5 speed swap, now check engine light?
just did a 5 speed swap drove it around for awhile no check engine light.
after about 10 min of driving now i get the light.
I have 0 wires connected to the trans, still need to source a speed sensor.
and fuk the reverse lights, dont need em. any idea what it can be before i go run some codes. is it normal? still using auto ecu
repda916 is offline   Reply With Quote
Old 02-07-2009, 11:26 PM   #2
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
S13 or S14?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-07-2009, 11:28 PM   #3
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
well what code did it throw? thats how you find out whats wrong
codunc is offline   Reply With Quote
Old 02-07-2009, 11:39 PM   #4
repda916
S13, and not sure what code, didnt know if this was a normal thing b/c of the auto ecu
Old 02-07-2009, 11:55 PM   #5
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
enough said. pull your ecu and see what code it gives you
おれのシルビア大好きだよ!!!
aoiken3 is offline   Reply With Quote
Old 02-07-2009, 11:56 PM   #6
DreamN
DreamN's Avatar
Trader Rating: (54)
if it's an s13 then the code shouldn't be the cause of the 5 spd swap as far as I know. plus since it's an s13 why haven't you just checked the codes already? it takes less than 5 min. to do.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-08-2009, 12:31 AM   #7
repda916
i got a code 55 which means everything is ok? i dont get it why would that come on?
Old 02-08-2009, 02:06 AM   #8
s14l0v3r
Trader Rating: (25)
s14l0v3r is an unknown quantity at this point
Feedback Score: 25 reviews
cuz auto ecu most likely.
s14l0v3r is offline   Reply With Quote
Old 02-08-2009, 04:50 PM   #9
DreamN
DreamN's Avatar
Trader Rating: (54)
^ nope. he has an s13. having the auto ecu wouldn't affect it.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 02-08-2009, 08:28 PM   #10
repda916
its on again after resetting it.
NOW i have more problems after this swap
my right head light will work normal and with brights
my left head light will only work with brights.
tried a different housing, same problem. checked fuses under hood. and kick panal. what could it be?
Old 02-08-2009, 10:50 PM   #11
bhcsilvia
bhcsilvia's Avatar
bhcsilvia is an unknown quantity at this point
u have to make sure code 55 cuz 54 is A/T control code there is a difference between auto and manual 5spd ecu's i did on a S14 on the head light there are 2 fuses for head light at engine compartment last fuse by its self 15amp blue make sure the is power there with test light and also check the connector and the bulb wire green w/yellow stripe.
bhcsilvia is offline   Reply With Quote
Old 02-09-2009, 12:02 AM   #12
repda916
and once again ANOTHER problem has came up.
after clearing the codes on the ecu more have came up
15 - Mixture ratio is too lean despite feedback control; fuel injector clogged
and
34 - Detonation (Knock) Sensor
If i fix the injector problem will the knock sensor code go away or is is just bad?
Old 04-18-2009, 10:37 PM   #13
superbraut
superbraut is an unknown quantity at this point
delete .
delete .
superbraut is offline   Reply With Quote
