Old 03-14-2006, 09:32 PM   #1
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
we have a go on the RB swap
Just thought i'd let you know, after:
buying a S15 SR20 In japan
Moveing back to US
Motor anlong with cash for extras never showing up
waiting a year
re-saveing up
talking to Dave for a long ass time about picking up a RB
slowly haveing the guy starting to pay me back
I am finally starting the swap into my car that i have been planning since 2003 .. RB25DET 1998 240sx.
i will put in pics and updates as i go along, but any advice is welcomed since i don't have swap knowledge. Anyone around San Diego is free to help.
Just thought i's share this with everyone as i have been talking about it/buying shit/selling shit/buying more shit for the longest time and i am happy as hell to finally get it going. car is in the shop today, RB should be showing up tommarow. it's about damn time.
Here is cliffs of this entire thread:
Day 1
So I went to upload the pics from today to Photobucket and my memory card decided that it didn't want to store any of the pics. so it will be tomorrow with the pics i guess.
Happened today:
Front bumper removed
Center panel removed
Auto shifter mechanism removed
All fluids besides brake and power steering removed
Air intake remover
Lower engine harness removed
Fan/fan shroud removed
Radiator removed
Stared at OK looking wemen
Called around trying to get people to show up that said they would.... no dice
Broke a creeper
Car on jack stands
Watched a guy pull a V6 out of a firebird in a little over 2 hours while i was still working on shit
Took pics that didn't work
And lastly found out that the Water pump face on the RB was bent, so it looks like I will have to get a new water pump.
3-18 Morning
Afternoon:
Out with the old
Soon to be in with the new:
Clean way to drain the PS pump:
And you can see where the pulley has been rubbing on the bent water pump:
that's it for today. I think that once i get the water pump i will be making a RB water pump replacement FAQ with pics for future use.
3-19
skyline X-member in :
be sure to use a pry bar and jack to get the LCA's in
Cali lift:
RB intimate pic:
This is going to get flushed out:
3-23
Got the new motor mounts from Drift Freaq/Syko performance:
3-24
So the engine is almost in. I had to remove the igniter to get it in, and the brass looking tube that cones off the brake booster to get the engine past the lip and into the bay.
I spent a little over an hour and manned to get 1 motor mount to line up. Tomorrow will be another one.
As you can see I said hell with it and used the stock Power steering loop highly modified until the time where i buy a trans coolant to use for the P/S
Also to Drift Freaq you might want to include the fact that the power steering hose needs to be 3/8 hose not 5/16 hose like it states in your install to fit on the rack.
Ready to install bay:
and the sway bar spacers:
Also i am ditching these 2 lines that were attached to the KA as they are useless evap stuff. i am thinking to block them off:
#1
#2
Any help with those would be appreciated.
Word to the wise: don't accidentally dip your hair in gear oil that split out of the trans when getting your motor into the engine bay. I've washed my hair about 7 times and it still stinks
Also he S14 power steering rack nozzle has a 3/8 output on my car. but i did notice that the R33 had 2 different size metal hoses, you were probably talking about using the small one.
But for anyone that wants to hook directly up to the S14 rack nozzle, don't be like me and get a ride to the parts store only to return and find that you need bigger hose.
3-25
Busy day at the shop today
I got the engine in. Had to pry bar the tunnel (do yourself a favor and hammer it back while the engine is out) around the starter housing, move a few hoses around, and move this vent thing:
also you have to take off the igniter, and use a jack to lift the trans while sliding it in and you can get it in with all the pullies on. That and it worked best to mount the motor mounts to the engine and not to the x-member.
Then I had to pry to get the trans mounts to line up, but they did. Drive shaft fits perfectly.
Here’s how it sits with the Syko mounts:
Also when I put the engine in I left the shifter on (the stick) and it fit fine.
on the down side when I was messing with getting the engine in i notices that the hose that goes into the steering rack got flattened out (see pic above hose in middle goes out, now it is flat) so I am going to have to bend and hope on that next time i am working.
the turbo outlet/down pipe is a BITCH!!!! Syko kit provides 2 bolts (cause the stock won't fit) for the sides, and I am here to say that those 2 side bolts are horrible. they are 12 sided, so a 11mm open or a 10mm closed wretch. but there is no clearance on the upper one so I took the open 11 and had to put it parallel to the ground coming out of the bolt and twist by turning my fingers. my had was cramped to hell by the time I was done. EDIT ATTACH DOWNPIPE BEFORE INSTALL TIP COMES FROM SYKO and the proper tool is a standard 12pt 10mm wretch.
Also hooked up fuel lines, they are 5/16 and i found out that the factory fuel filter holder will hold a 300zx fuel filter without breaking a sweat. I just bent it out a bit and the filter popped right on and is held securely.
Lastly here is mount solution to the throttle cable issue. I read on how Henry did it, and I was looking at my bent to hell stock bracket and thought that by the time I finished straightening that one and doing the mod I could have built my own. So I checked for clearance and went to cutting on a block off from my auto trans and 30 min later I had this:
No throttle
WOT with no clearance issues:
Later I will worked on the angles some more and also securing the throttle cable to things, but I have a metric shit-ton of stuff laying around from the KA so I am not worried.
that was my day from about 11-4
3-28
Mellow- for cooling i am sporting 2 10” HP perm cool fans---- got too good a deal on them to pass up plus between them both should push 2500cfm (http://www.perma-cool.com/Catalog/Cat_page16.html)
*******THEY DO NOT WORK, GET FAL DUAL 12 PUSHERS*******
Today I wasn't paying attention to the time and only got like 2 hours of work in.
The List:
-Drained trans/cleaned plug
-Filled trans back up 3 bottles Royal purple
-connected clutch line
-filled/bled clutch
-made big power steering line fit that bolts into PS pump
-Found out that the small line has to be replaced, but it's not high pressure so should be no problem
Getting vacuum diagram from Gary (thanks) so the mystery of the lines will be solved.
3-29
New stuff:
The mounts**** EDIT, you do not need the heat shielding with the SYKO mounts!****:
Got the heater hoses connected today. They were a bitch.
here are actuator and mysterio hoses that i was wondering about before:
and after:
Yes I realize that it is wrong. I just realized tonight that the hybrid FMIC kit uses 1 or the stock pipes with a nipple on it so i am going to hook that up to the pipe rather than where it is right now and block off that small hose pictured.
The other 2 hoses blocked off and unbolted:
My handy dandy reverses Power steering line:
Also for the big power steering reservoir return line I bought 1.5 feet of 5/8in hose and used that to connect it, perfect fit.
Now I am fumbling through the wiring, but Gary is willing to work with me on it so I am not quite so confused so. problem is that I had an OBD II and have never disconnected the wiring on a RB before so it is really hit and miss on me finding where all the stuff goes since I have about 10-15 extra OBDII plugs that I don't use now. But when I run into something rather difficult I will include it here.
It is the fuel pressure dampener, helps to cut pulsations in the fuel lines, and Not totally necessary.
3-30
Another day at work! Got all the wiring installed today. It was really easy thanks to Gary. thanks!
I am working on some pics to show you where some of the harder stuff was at.
I never took the harness off the car, but I was able to put everything back on. Here are the 3 hard wires to get:
the two green ones are knock sensors that are round and have 1 prong on them. the green is where a blue plug goes onto. that one i never would have found without Gary telling me about it. still to come where the wiring goes.
But then I went to the intercooler piping. Now this stuff is a biatch.
The kit is the Hybrid kit for the R33 RB with S14 mounts. And boy is it interesting! Here is me trying to fit it:
and me denting it trying to bend it:
It does not like me at all right now for as far as i can tell this fits my car as well as it would fit a F250.
So I said screw it and went to the other pipe to see if it was a bit more cooperative.
things looked good!
And it worked!!!
Next issue is that damn power steering hose. I am going to have to find another way to mount it. Looks like I am going to have to get all sneaky sneaky with it to get it to fit.
not too bad, about 4 hours today.
3-31
OK once again I forgot my camera. I think I am going crazy. All I have to say today is that I worked on my IC piping and mounting from 3pm-730pm and that i would rather gouge my eyes out with a spoon than buy a hybrid piping kit again. NOTHING and i repeat nothing fits like it is supposed to. allot of hacking and hole sawing later i have the piping 1/2 way working, but it still needs to be cut more. And 1/6 mounts might fit. That is right the only 2 mounts that 1/2 way work are directional and they sent me 2 lefts. BOO HYBRID!!!!
4-1
OK I remembered my camera today...... but forgot to get the battery out of the charger.
So I finally got the radiator hoses after running around all day I ended up with this:
And at $70/hose I feel like I just raped by all 3 pep boys.
Both of these are the 2 foot length. pics later on what I did wit them.
Also hybrid kit I found out that 0/6 mounts work. I had to hack the mounts to make so the headlights could sit in there, more on that later also.
What I did today:
Mounted electric fans
Hooked up Inter cooler top mounts
Hooked up and re sized all inter cooler piping to work
Made inter cooler upper mounts work
Found, sized and installed radiator hoses and temp sensor
Left to do tomorrow:
Make and attach lower IC brackets
Re-connect all rear battery wiring/power distribution blocks
Attach intake
Change oil
Start engine to make sure it is all good
Assemble car and drive away.
Oh yes........................... i should be done tomorrow and it's about damn time.
4-4
IT'S ALIVE AND RUNNING!!!!!
So I am driving it around today. One thing that took me awhile to figure out is the screw to bleed the coolant system. Here it is circled in yellow:
Basically took a funnel and shoved it in the radiator when cold, then poured coolant in it until the hole that the screw was in had coolant coming out without bubbling.
As far as the ride height goes, I will have pics soon, but it used to have a 2.5 finger gap on the front wheels, now it is a 2 finger gap. And that is with tokiko blues and RSR TI2000 springs.
PICS:
Also as mentioned by everyone else the strut brace won't fit because it hits the throttle assembly. Also my ARC induction box is a no go cause of it being too big. So invest in a pop or cone filter.
Yeah my Origin front bumper is going on vary soon. Also i broke a hose clamp on the IC tonight, or course it had to be pouring when it happened, but luckily i had a spare radiator hose type clamp. I think I will be switching all my clamps over to that type.
Just to re confirm it, I broke a screw on the hybrid clamp kit with stock RB boost.
Once again, that kit is not the best... you save money, and with a lot of effort it can be made to fit, at least i didn’t have to weld anything.
Some loose change I am still working on:
Correct temp sender
Trim the auto brake pedal slotting the holes in the KA ECU holder so the ECU will fit
Eventually hook my SAFC back up
Type R BOV
Trading my ARC intake box for a filter that will fit
4-8OK I went to NAPA and CARQUEST and they list one generic sender that is for all Nissans 93-99..... Which is wrong? After a lot of head ache I tracked it down to AutoZone as a water temp switch that is a Wells TU222 that is the one for a S14 stock gauge. Learn from my headache. Also the brand new Napa thermostat isn't opening at the correct temp. It is opening at about 208 instead of 170 so I would also suggest the NISMO low temp unit (Part number 21200-RS580) cause now I already paid 90 for a coolant flush to find this out and i will have to drain and replace the coolant while the motor is in the car. This will suck.
Fuel pumps being switched out (hopefully) Sunday.
And don't forget to change the oil filter, in my rush I forgot. It’s the same oil filter as a 300Z or S14 240sx. so look for both those when you cross reference it.
Any other little things jump up as possible problems I will address it as i go along.
4-9
I Installed the Walbro fuel pump today. Yes the one that broke because I ordered a second one and that one was broke too in the exact same spot. so JB weld to the rescue, let it cure for over 15 hours and tossed it in today.****EDIT DO NOT DO THAT< IT DOESN"T WORK GET A NON BROKE WORKING ONE***** It noticeably pulls harder at higher RPMs than it did before. of course I only pulled higher a couple of times before cause of fear of blowing the fuel pump. but now the only thing I really have left is the lot temp thermostat that i will be ordering Monday.
On a side note, my front tires now kind of squeal, but I am taking in for an alignment on Monday also so hopefully that will go away.
4-10
Here’s a pic for you (Nismo 21200-RS580):
I'll add how it was to change the thermo with the engine in the car after I am done. It’s only a 2/ 10 difficulty, but i will see.
4-12
What I went through to find out that my fans weren't pulling enough air:
My cooling system is turning into a 1500 ordeal.
OK realistic break down
Fans 60
Water pump 125
Radiator hoses 150
Radiator 310
Coolant flushes 95
Nismo thermo 55
Reg thermo 20
Bad sender 20
Good sender 17
New FAL fans 230
Fluid 10
Total so far: $1092
(not to mention that the Koyo and the fans are the second set i have bought so on new rad#2 and fans#3)
And I am going to switch over to water wetter, plus that doesn't include shop fees involved with messing around with the damn thing or the time I have spent on it. Then the only thin I will have left to change out is the radiator. (Or remove the FMIC maybe that is blocking too much air).
Well good news, since I moved the fans off the AC condenser and put them onto the radiator, I got it lasered today and it was @178deg at idle after driving it around for 30 min or so stop and go in the heat of the day. I think that the AC condenser was blocking too much air. Not I will put the cooling panel back on and see it that makes any difference.
took the cooling panel off because the fans have to suck air from somewhere, and since the intercooler is so big it is blocking allot of air.... but mainly cause I was running out of things to change up to get it cooler. And I didn’t mount it on the radiator to begin with because I like, and plan on keeping my AC if at all possible. When I get the FALs in i will see if I can put them on top of the condenser and hook that back up but there is only one way to find out if it will work, which is waiting for someone on Zilvia to find out the hard way and learn from their mistakes if they write it up.
Also just a thought on driving the car, the alignment was WAY off, so I got that fixed and it handles just like it did before the swap, witch is to say great. Only thing is that the RB seems to detest low speeds, I drive it NA most of the time and only am getting about 200miles to the tank (12-14MPG) I have heard that it should get a lot better than that, but I will update this as it progresses and gets the bugs worked out of it. I have went through 2 tanks so far, but it is just now coming out of the project stage (bought air filter today) ... oh and that low speeds thing, at under about 8or so MPH in 1st, and at the low ends of every gear it is a bit jerky, kind of like the clutch is engaging and disengage but i don't think that is the case since as soon as I give it gas it takes off with the quickness EDIT WAS THE FUEL PUMP BREAKING< THE ENGINE WAS GOOD AND THIS IS NOT THE CASE.. Once I get above parking lot cruising speeds it wants to go like it's cool. After riding in a friends SR a while back, the feeling of waiting and then the boost hits, isn't there, it is go go go go go..(Sound of turbo spooling up like a jet engine).boost and then you're really kicked back in the seat.
I think that the turbo noise is louder than the BOV, and that is loud too. but all in all this is a very civil engine when cruising around town. I pretty much stay off the boost and drive just as fast as my KA around town, but when I need the power! It's always hungrily waiting on tap to be let loose.
I really would like to see this engine at my goal of 300-350WHP, cause it is quick now.
And that's a night.
And these are for everyone who is thinking why I didn’t just hook the fans up as pullers:
4-24
Well I have been fighting problems for a while, but needless to say I have switched out 4 fuel pumps in 4 weeks so I deserve some sort of frequent flyer miles or some shit. At least a secured decoder rings if nothing else. Total count:
2 broke Walbro HP pumps
2 fine S14 pumps, one accidentally chucked
1 nice new Walbro HP pump currently installed.
And I will see what happens from here.
For reference faulty fuel pumps cause an ass load of strange problems to include:
No torque
Turbo spools but no acceleration
Acceleration and no turbo spooling
Decreased blow off
Sputtering/stalling
Air in fuel lines
Almost like a vacuum leak sort or problems, I know it's a bitch to get to the fuel pump, but it makes a good place to start troubleshooting the fuel system.
That is the write-up on the install. hope everyone enjoys it and learns from my mistakes. FYI that engine probably tossed a rod or something. Something was rattling around inside and cyl 5 was at 0 PSI. Now I have a new car and may end up with another RB.
Tenchuu is offline   Reply With Quote
Old 03-14-2006, 11:37 PM   #2
S14DB
AFC #1
S14DB's Avatar
1-888-carb-snitch
Old 03-15-2006, 12:06 AM   #3
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
he has out of state plates, so he's pretty safe here.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 03-16-2006, 10:13 PM   #4
Tenchuu
Tenchuu's Avatar
RB sitting next to my car, 1/2 of Drift Freaq's install kit in the car, waiting on the new redesighned motor mounts.
ended up with a series 1 RB25DET with 30194 KM on it, witch = 18,761.68 miles
also ended up haveing dave source it for me through kouki_s14's (uncle?) importer. Pics to come soon
here is cliffs on water pump replacement/timing belt replacement
Ok since i am doing this already and haven't found allot of good write ups here it is as i do it. This is a Series 1 RB25DET. I did this cause my water pump was bent so here it is:
Remove water pump pulley:
remove the CAS too that is held on by the obvious 3 bolts too
Remove bolt that holds on main pulley (it's a 27):
Use pulley puller to take the pulley out:
Remove all small bolts the holes are circled in red (they are T5):
take off this little guard:
MARK the timing belt in all 3 places. mark the gears and the belt so you can line them up later I labeled mine Rt, LT, and B (for bottom):
Now remove the timing belt tensioners:
and the back of the other one:
now the 12 bolts that hold on the water pump (you can see them in the pics above)
and you should be left with something like this, if not cleaner hopefully:
Thermostat:
unbolt the Oil dip stick and bend down slightly, Bent the metal hose CAREFULLY that is by the bottom left screw, unbolt:
install: make sure the little jiggle valve on the thermostat is facing up, put a good bead of RTV on both the inside and the outside lip of the thermostat, place back in the hole and tighten down bolts (16-23 N/M). done and done.
OK well i kinda owned myself by forgetting the camera when i put this back on. and for torque specs and bolt order i used a RB25DET.org writeup here (i take no credit):
Water Pump Replacement
Removal
1. Remove radiator
2. Remove belts
3. Remove water pump pulley
4. Remove timing belt
5. remove tensioner pulley
6. remove idler pulley
7. remove alternator adjustment bar
8. Remove bolts in order shown
Installation
1. Apply sealant (Nissan RTV)
2. Tighten bolts in the order shown below
3. Tighten bolts 8and 9 together with the alternator bar
4. Tighten bolts to specs (FT/LBS)
M6 = 4.6-6.1
M8 = 11.8-15.5
M10 = 23.2-31.1
now to put it back on, i lined up all the marks on the belt and the gears so it was back in place. Next i installed the idler pulley and torqued to 43-58 (N-M) (the idler is the one on the rt if you are in front of the engine)
Then it was time for the tensioner. you need a hex wrentch to get this thing to go on.
so i made sure that the spring on the back was seated good in it's slot. then made sure that the nut on the end went
(nut)---->( shaped washer---->l shaped washer--->pulley---->bolt
then after i had all that in and i used the hex wrench to turn it so i had clearance to get the belt on. i ended up takeing the belt off the bottom pulley, looping it around the tensioners, then sliding it back onto the bottom gears and le tit go. Now i torqued that nut down to .43-58 (N-M) also. then it was a matter of putting on everything the same way it came off (block off plate, then front shielding, then bottom pulley, then upper plate and lastly the CAS and water pump pulley.)
I will let everyone know if this works once i start it up and see. i hope it does and will find out soon.
Runs fine it works, all is well good info.
Old 03-17-2006, 02:37 PM   #5
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Nice, nice. Definitely keep us posted.
Neejay is offline   Reply With Quote
Old 03-17-2006, 07:02 PM   #6
Tenchuu
Tenchuu's Avatar
so i went to uplaod the pics from today to photobucket and my memory card decided that it diddn't want to store any of the pics. so it will be torrarow with the pics i guess.
happened today:
front bumper removed
center panel removed
auto shifter mechanism removed
all fluids besides brake and power steering removed
air intake remover
lower engine harness removed
fan/fan shroud removed
radiator removed
stared at OK looking wemen
called around trying to get people to show up that said they would.... no dice
broke a creeper
car on jack stands
watched a guy pull a V6 out of a firebird in a little over 2 hours while i was stilll working on shit
took pics that diddn't work
and lastley found out that the Water pump face on the Rb is bent, so it looks like i will have to get a new water pump, or use that one and risk that the wobble in the bracket isn't enuff to throw the alternator/water pump belt. What do you guys think?
Old 03-18-2006, 12:58 AM   #7
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
I'd replace the pump, thermostat and timing belt regardless. But it sounds like you're dropping it in true OEM form, no upgrades or maint?
Better luck with the pictures
MELLO*SOS is offline   Reply With Quote
Old 03-18-2006, 11:14 AM   #8
Tenchuu
Tenchuu's Avatar
well the thing started out with a couple of guys i know heliping, thermostat is getting checked/replaced, all the outside belts are getting replaced, i debated the timeing belt, but decided against out the door, all the pumps and timeing where supposed to be down the road a bit (read once sammer boy returns the other 6000 he owes me) so i was trying to top this swap out around $5000 and 2-3 weeks instead of 7-8000 and 2 months witch i don't have before i move.
Old 03-18-2006, 06:50 PM   #9
Tenchuu
Tenchuu's Avatar
Vid up
http://youtube.com/watch?v=n66jx7-let0
vid
Old 03-18-2006, 08:26 PM   #10
Tenchuu
Tenchuu's Avatar
Today:
morning
Afternoon:
Out with the old
And lastley you can see where the pulley has been rubbing on the bent water pump:
Old 03-18-2006, 09:12 PM   #11
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
looking good tenchuu, looks like stuff is going to move quickly next weekend.
New Video
Buy my mounts!
Old 03-18-2006, 09:25 PM   #12
Tenchuu
Tenchuu's Avatar
Yeah i would love to have this done by next monday....
Old 03-18-2006, 11:06 PM   #13
SimpleSexy180
nice! <3 cant wait to see more progress.
SimpleSexy180 is offline   Reply With Quote
Old 03-19-2006, 12:52 AM   #14
Neejay
Neejay's Avatar
That engine looks clean/good man. Good job.
Old 03-19-2006, 12:04 PM   #15
RSP13-Sideways
RSP13-Sideways's Avatar
RSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her self
Send a message via AIM to RSP13-Sideways
Nice work, hahaha your video is funny man. You're over there filming your bent water pump pulley when you should be installing a new one hahaa...
Great stuff though man, looking good Marine!
- Jay
WTB: Nothing at the moment. LEWL
WTS: Everything sold, thanks folks!
RSP13-Sideways is offline   Reply With Quote
Old 03-19-2006, 12:16 PM   #16
ThatGuy
Admin Asshole
ThatGuy's Avatar
Somebody trade me a RB26 for a pair of KA's. I wanna get in on the swapping fun.
Old 03-19-2006, 12:20 PM   #17
NemeGuero
No more nissan.
NemeGuero's Avatar
I'll take your exhaust cam, Barry!!
Looks good Tenchuu. Wish I were local to help.
Haha, and yah, that video is funny.
Old 03-19-2006, 09:14 PM   #18
Tenchuu
Tenchuu's Avatar
X-member in :
be sure to use a prybar and jack to get the LCA's in
Cali lift:
RB intimate pic:
Old 03-19-2006, 10:02 PM   #19
Tenchuu
Tenchuu's Avatar
and makeing a tch thread for the RB shit I am doing:
http://www.zilvia.net/f/showthread.php?t=104433
Old 03-19-2006, 10:10 PM   #20
NemeGuero
No more nissan.
NemeGuero's Avatar
Go tenchuu!! its' your birthday!
Old 03-23-2006, 12:45 PM   #21
Tenchuu
Tenchuu's Avatar
Got the new motor mounts from Drift freaq/syko performance:
Old 03-24-2006, 02:18 AM   #22
!Zar!
!Zar!'s Avatar
You are living one of my many dreams. Good luck with the swap.
Old 03-24-2006, 09:47 PM   #23
Tenchuu
Tenchuu's Avatar
so the engine is almost in. i had to remove the ignitor to get it in, and the brass looking tube that cones off the brake booster to get the engine past the lip and into the bay.
i spent a little over an hour and maned to get 1 motor mount to line up. tommarow will be another one.
as you can see i said hell with it and used the stock Power steering loop highly modified until the time where i buy a trans coolet to use for the P/S
also to Drift freaq you might want to include the fact that the power steerign hose needs to be 3/8 hose not 5/16 hose like it states in your install to fit on the rack.
ready to install bay:
Also i am looking for help on what to do with these 2 lines that wer attached to the KA and i gots no clue. right now i am thinking to block them off:
#1
#2
any help with those would be appreciated.
word to the wise: don't accidently dip your hair in gear oil that spilt out of the trans when getting your motor into the engine bay. i've washed my hair about 7 times and it still stinks
Old 03-24-2006, 10:06 PM   #24
S14DB
AFC #1
S14DB's Avatar
Evap purge system.
Get rid of the black box too.
Old 03-25-2006, 12:41 AM   #25
NemeGuero
No more nissan.
NemeGuero's Avatar
Have you removed the whole line, AJ? What went where that picture is?
Old 03-25-2006, 02:22 AM   #26
Tenchuu
Tenchuu's Avatar
so i take it both 1 and 2 are trash and i should just off them and it really doesn't matter if i plug them or leave them open.
Old 03-25-2006, 02:53 AM   #27
S14DB
AFC #1
S14DB's Avatar
Possible that the gas tank may explode if the evap can is left on. I would remove it.
The Map/Baro should be a part of the KA harness. Which I don't understand why you didn't remove it.
Old 03-25-2006, 10:28 AM   #28
drift freaq
Ken, the right hose might have been on your clip and fell off in the transfer. when the clip was trucked down to you. Usually you use the power steering hoses from the R33 clip or motorset not the s14 ones. hence,why you have that difference.
New Video
Buy my mounts!
Old 03-25-2006, 10:39 AM   #29
Ritz S14
Ritz S14's Avatar
Gas tank explode if you leave the evap on? that's pretty unlikely. I'd say it's more of a possibliity if you were to remove the evap system, and not plug the gas tank.
Ritz S14 is offline   Reply With Quote
Old 03-25-2006, 10:40 AM   #30
Tenchuu
Tenchuu's Avatar
cool, i was just letting you know that the S14 power steering rack nozzle has a 3/8 output on my car. but i did notice that the R33 had 2 different size metal hoses, you were probibly talking about useing the small one.
but for anyone that wants to hook diectly up to the S14 rack nozzel, don't be like me and get a ride to the parst store only to return and find that you need biger hose.
