Old 07-01-2008, 02:47 PM   #1
Zero_X
Zero_X's Avatar
Zero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to behold
s14 vss...
ok so i have a 98 s14 with a s13 tranny..speed is reading double of what it is..i know i have to switch out the vss but should it be s14 vss or s13 since its a s13 tranny?? help anyone?
THREE AMIGOS!!
Zero_X is offline   Reply With Quote
Old 07-01-2008, 03:25 PM   #2
projectRDM
projectRDM's Avatar
We always suggest for someone to search, since I seem to type this weekly.
VSS must match the cluster. Nothing else matters. Transmissions are the same from 89-98, you don't have an 'S13 transmission', you have a transmission removed from an S13.
FORMERLY R240NA
Old 07-01-2008, 03:32 PM   #3
Zero_X
Zero_X's Avatar
thanks...appreciate it..
THREE AMIGOS!!
Old 07-01-2008, 03:39 PM   #4
issac
issac's Avatar
issac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really nice
I figured instead of creating a new thread i can just threadhustle this one. I just completed an auto to manual swap in my 95 using s13 tranny. My Q is I purchased a new s14 vss that came without the gear can I transfer the gear from the s13 vss? I searched but can not find the correct answer. I know this topic is covered to death but the info is sketchy.
issac is offline   Reply With Quote
Old 07-01-2008, 04:01 PM   #5
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
No you cannot swap the pinion gear from a S13 to S14 or vice versa, and you cannot use a auto pinion gear on a manual speed sensor and vise versa.
Old 07-01-2008, 06:52 PM   #6
issac
issac's Avatar
Thanks UNISA. much needed info. nuffrespect.
Old 07-01-2008, 11:12 PM   #7
onepuff
onepuff's Avatar
onepuff is on the path to ruinonepuff is on the path to ruinonepuff is on the path to ruin
Also the 89-98 trans are not the same exactly. You'll be missing the cranks position sensor. S14 have one S13 don't. OP you will have a CEL without it.
onepuff is offline   Reply With Quote
Old 07-01-2008, 11:24 PM   #8
issac
issac's Avatar
I realized that a little too late. Any possible ways to get around that (trick wiring etc...?) For CEL purposes only.
