Old 10-04-2008, 09:19 PM   #1
zilvialatorre
zilvialatorre's Avatar
zilvialatorre is an unknown quantity at this point
install kouki tails(s13) to my 93- 240hatch
how do i install a kouki tail lights on my old 93 hatch-
i just have the bare kouki tails with no socket and wiring.
my original tails has no lamp socket just a push in lamp(u know the orig)
how do i install my kouki tails w/o burning the socket receptacles?
or are the any replacements for the sockets and wiring?
pls. advice guys ned help.....
zilvialatorre is offline   Reply With Quote
Old 10-04-2008, 10:15 PM   #2
projectRDM
projectRDM's Avatar
Pretty simple, get the sockets. You need them.
FORMERLY R240NA
Old 10-04-2008, 11:00 PM   #3
zilvialatorre
there are no sockets from my original tails... its a push click lamp holder
the socketsthat i need for the kouki are smaller and lamps are smaller too
because the lamp sockets or hole in the kouki are smaller.
the original tails have only 2 sockets these are reverse light sockets that are lamps in the center garnish area. these sockets are bigger too.
the brake lamp and the signal lamp sockets is what i need for the kouki because they are smaller in size. the orginals dont have lamp sockets they used a push click(sideways) lamp mount.
thanks
Old 10-04-2008, 11:03 PM   #4
zilvialatorre
pls advice if there are sockets around that i can use for these kouki tails(hatch 93). or some way to install the tails avoiding burning the lamp socket holder of the tails per se. i need help man !!!! i bought these knowing its plug and play. my bad. !!!!
Old 10-04-2008, 11:06 PM   #5
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
what he is saying is that you need to somehow acquire the harnesses for the kouki tail lamps. you cant install the lamps without them. my best guess is to go ask a nissan dealer to get them for you. and while you are there get some butyl tape to seal the lights with. i believe that once you get the harnesses you also need to spice them with the older tails connectors because they are different.
https://instagram.com/e_lemonation/: @e_lemonation
Old 10-04-2008, 11:07 PM   #6
projectRDM
projectRDM's Avatar
thanks
I know this. What part of my response did you not understand?
Let me say it again. You need to get the correct sockets.
Call whoever you bought the lights from and get them. You can't do anything without them.
FORMERLY R240NA
Old 10-06-2008, 11:13 AM   #7
zilvialatorre
hello zilvia !!!!!
who knows where to get the socket lamps for my kouki tails(US Nissan dealers dont have them)
to be installed in 93 s13 hatch? or any replacement socket that i can use?
thanks for advice
Old 10-06-2008, 11:30 AM   #8
S14DB
AFC #1
S14DB's Avatar
Go to the parts store. In the Electrical or quick repair section they should have bulb sockets.
Old 10-06-2008, 11:34 AM   #9
slider2828
slider2828's Avatar
The real answer is either get them from the owner OR make it yourself OR you will need to contact like courtesy nissan to see if they can source you the originals from Japan....
Turn and Burn!
Old 10-06-2008, 11:47 AM   #10
nismo 240sx
nismo 240sx's Avatar
nismo 240sx has a little shameless behavior in the past
or just call justin at the nismo shop in westcovina...
nismo 240sx is offline   Reply With Quote
Old 10-06-2008, 11:53 AM   #11
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
Nissan 180SX Kouki Rear Tail Light Socket Assembly
there you go dude.
louisdaboois is offline   Reply With Quote
