Old 07-17-2008, 07:02 PM   #1
VAs13
VAs13's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
constant power problem
so right when i hook up the battery, my safc and all my cluster dummy lights come on and stay on until i unhook the battery, i even unplugged the ignition switch plug and they still stay on, anyone have any idea whats wrong
Old 07-18-2008, 03:54 AM   #2
Skids2212
Skids2212 is an unknown quantity at this point
you have a short....start unplugging fuses until the lights turn off.... that will tell you where the power is comming from....then just trace and look for the short
Skids2212 is offline   Reply With Quote
Old 07-18-2008, 11:57 AM   #3
VAs13
VAs13's Avatar
Trader Rating: (28)
when i removed FL25A___ENG CONT the safc n that shut off
Old 07-19-2008, 02:23 AM   #4
Skids2212
look at a wiring diagram and look at what that fuse powers....the easiest way to find the short is to plug the fuse back in and unplug connectors on that circuit, eventually you will unplug a connector and the power will go away, then you can look at the wiring past that connector for the short, thats the simplest way to narrow the short down.\
what year is the car?
Last edited by Skids2212; 07-19-2008 at 02:28 AM.. Reason: forgot to ask what year the car was
Old 07-20-2008, 01:50 AM   #5
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
the problem's in your lower harness. use the lower harness that came with your car, or rewire your new lower harness so it's correct for your year/original transmission set up.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 07-20-2008, 03:29 PM   #6
VAs13
VAs13's Avatar
Trader Rating: (28)
well i got it taken care of, i took the harness off my old car and it works fine
Old 07-20-2008, 04:34 PM   #7
Z U L8R
Z U L8R's Avatar
and there ya go
good job on the fix
Dave =]
Old 07-21-2008, 09:47 AM   #8
Catch240
Catch240's Avatar
Catch240 is on the path to ruinCatch240 is on the path to ruin
the samething was happening to me when a while back. The prongs on my lower harness alternator plug were bent and not connecting right to the body harness.
Catch240 is offline   Reply With Quote
