Old 08-02-2008, 06:45 PM   #1
95Kouki
95Kouki's Avatar
95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough
s13 !!! - FS: S13 Fastback...The Works - !!!
Posting this car for a good friend of mine.
This is an 89' Nissan 240sx with 150 miles on complete build. The car was repainted Canteen Green from the US Version Nissan Xterra and Titan, which looks amazing! There was no motor, transmission or interior in the car and all sound tar had been removed when it was painted, so it allowed for a proper job. The front and rear fenders have been replaced (front)/rolled and pulled (rear) to 20mm (front)/1.25" (rear) to allow for the perfect fitment of the 9" and 10" low offset 5zigen wheels. The SR20 motor was hand picked form XS Engineering where it was Compression and Leak Down tested before leaving the shop. Every aspect of this vehicle has been taken into consideration and no expense has been spared on this project. This is the ultimate drift/show vehicle and has everything you could ever need!
Interior:
OEM Nissan S13 Radio Bezel: $99.95 (West Covina Nissan)
S14 Seatbelts: $50.00 (eBay)
OEM Nissan Pedal Set: $64.13 (A to Z Auto Salvage)
Taylor Battery Box: $159.95 (Summit Racing Equipment)
OEM Nissan S13 Dash: $250.00 (eBay)
Nismo GT Spec Shift Knob: $75.00 (Phase 2 Motortrend)
Circuit Sports Drift Knob: $14.25 (Phase 2 Motortrend)
3 Pod Gauge Bezel: $22.00 (Dave Reagan)
Powdercoat Gauge Bezel: $20.00 (Aries Blasting)
Bride® Seat Rail (L): $180.24 (West Covina Nissan)
OEM Nissan Shift Boot: $45.00 (Antelope Valley Nissan)
Carbon Fiber Sheet (Wet): $30.00 (Dream Sport)
Bride Zeta III (Red): $760.95 (Aspec)
Works Bell Short Boss Steering Hub: $150.00 (Aspec)
Works Bell Rapfix II Steering Wheel Quick Release: $298.00 (Aspec)
Works Bell Hub Lock: $120.00 (Aspec)
Auto Custom Carpet Front Floor Mats: $44.95 (Stock interiors)
Exterior:
89' Nissan 240sx Base Model Rolling Chassis: $700.00
180sx Position Lights: $145.70 (OptionImports.com)
5Zigen FN01RC (4/Bronze): $1013.00 (Bestway Autosports)
Federal 595SS 225/45/17 and 235/45/17 With 150 Street Miles
5Zigen Lug Nuts (Red): $100.00 (Bestway Autosports)
JDM Kouki Taillights: $499.95 (Phase 2 Motortrend)
OEM Nissan Headlight Assembly: $54.13 (A to Z Auto Salvage)
Version:SELECT 180sx Version III Front Bumper: $218.33 (Version:SELECT)
Version:SELECT 180sx Version I Rear Bumper: $218.33 (Version:SELECT)
Version:SELECT 180sx Front Fenders: $260.00 (Version:SELECT)
*(Body Kit Pricing Reflects Full Kit Pricing, Including Side Skirts)
180sx Quarter Glass: $250.00 (Bestway Autosports)
House of Kolor F14 Rainbow Flake: $45.67 (Antelope valley Auto Paint)
Rear Window Mouldings: $221.70 (Antelope Valley Nissan)
Paint and Body Work: $6,000.00 (Affordable Auto Body)
Painted Canteen Green From The US Xterra and Titan Models
Everything Was Removed When Painted; Including Motor
New Front Windshield: $235.00 (Antelope Valley Auto Glass)
Motor:
Nissan Red Top SR20: $1800.00 (XS Engineering)
Modification To Muffler: $60.00 (Eastside Muffler)
Greddyä Oil Block Sandwich Adapter: $56.00 (Options Auto Salon)
Greddyä Radiator Hose/Water Temp. Adapter: $23.25 (Options Auto Salon)
OEM Nissan Lower Radiator Mounts: $20.13 (Antelope Valley Nissan)
Circuit Sports Coolant Reserve Tank: $95.00 (Phase 2 Motortrend)
Nismo® Engine Mount (R): $75.00 (Phase 2 Motortrend)
Nismo® Engine Mount (L): $75.00 (Phase 2 Motortrend)
Nismo® Transmission Mount: $65.00 (Phase 2 Motortrend)
Circuit Sports Hood Damper: $99.00 (Phase 2 Motortrend)
Greddyä Type RS BOV: $200.00 (Garage Works)
Greddyä M-Spec Intercooler: $780.00 (Garage Works)
BOV Recirculation Kit: $20.00 (Garage Works)
AEM Filter Kit: $60.00 (Garage Works)
OEM Nissan Water Pump and Rear Main Seal: $80.00 (Garage Works)
OEM Nissan Z32 Fuel Filter: $20.00 (Garage Works)
Motor R&D: $1666.00 (Garage Works)
OEM Nissan Manual Cross Member: $20.00 (Garage Works)
Used SSP Driveshaft: $80.00 (Garage Works)
OEM Nissan Clutch Master Cylinder: $45.00 (Garage Works)
OEM Nissan Clutch Slave Cylinder: $30.00 (Garage Works)
OEM Nissan Power Steering Belt: $20.00 (Garage Works)
OEM Nissan SR20 Fan Shroud: $45.00 (Performance Nissan)
Samco Radiator Hose Kit: $85.00 (Option Imports)
5Zigen Border 304 Max Exhaust System: $598.99 (Phase 2 Motorsports)
XS Engineering Downpipe: $99.00 (Phase 2 Motorsports)
Koyo S13 SR20 Aluminum Radiator: $285.00 (Phase 2 Motorsports)
Walbro G35341 255lph Fuel Pump: $99.95 (Phase 2 Motorsports)
Suspension:
Circuit Sports Aluminum Subframe Spacers: $71.25 (Phase 2 Motortrend)
Orange Tree (Battle Version) "RUCA": $229.00 (Phase 2 Motortrend)
Stance GR+ Pro Coilovers: $1,200.00 (Stance USA)
Drivetrain:
Ichiba 5 Lug Conversion (Front): $275.00 (Phase 2 Motortrend)
Ichiba 5 Lug Conversion (Rear): $275.00 (Phase 2 Motortrend)
Resurface Flywheel: $80.00 (ACT)
ACT Heavy Duty Clutch Kit: $389.95 (ACT)
OEM Nissan Z32 Brake Conversion (Front) With Steel Braided Lines (4): $450.00
OEM Nissan Z32 or Other Brake Master Cylinder Will Be A Necessary Upgrade In Order To Achieve Maximum Performance From These Brakes
S14 VLSD: $250 (Not Installed)
Electronics:
Apexi Turbo Timer: $103.00 (Option Imports)
S13 Turbo Timer Harness: $16.15 (Option Imports)
Defi BF Boost Gauge: $217.60 (Option Imports)
Defi BF Water Temp Gauge: $190.40 (Option Imports)
Defi BF Oil Temp Gauge: $190.40 (Option Imports)
Defi Control Unit (Version 2): $103.00 (Option Imports)
Energizerä Battery: $69.99 (Pepboys Auto)
Miscellaneous:
Miscellaneous Bolts, Clips, Fasteners, Etc: $31.52 (Antelope Valley Nissan)
Additional Labor: $3,250
Asking Price 17,500 OBO
People will always be haters...can't change that...just out drive them
95Kouki is offline
