![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
transmission problem
just did my 5 speed swap, took it to a shop to have it "professionaly" done.
drove it home it was ok, clutch engagement is really hight 1/2" from full release.. now when i put it in gear clutch in and try to push the shifter into gear it doesnt let me, it makes a buzzing sound, and i feel vibration on my clutch pedal, it like that with 1-5th gear. when i do get it in gear after playing wit the shifter and clutching in multiple times , when i let off it makes a screching clunking sound. and then goes, once in gear its fine... when i give it over 2000rpms or try to shift hard, it doesnt let me get into gear, and it makes the screching noise.. at times a ringing... so is it a throwout bearing/pivot fork problem? or a gearbox problem? thanks btw ka24de tranny, 6puck sprung hub clutch, stock flywheel
s14 kouki ka-t |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
well you have a pretty hardcore clutch. if it makes a whinny noise when your foot is off the clutch chances are ints the throwout bearing. if not then maybe your input shaft bearing might need a glance. also did you break it in right or did you do the swap and romp on it?
well i took the car back their..
i wasnt abusing the clutch at all, took it up to 2k once to see if it would grab. any idea why the engagement point is so high up?
s14 kouki ka-t |
![]() Join Date: Dec 2006
they probably forgot to put gear oil in it
#5 | |
![]() Join Date: Dec 2002
You should have about 1/2" of freeplay in your clutch pedal before clutch disengagment. And on a 6-puck you're gonna get ALOT of grabbiness and jerking in daily driving. Maybe they put the disc in backwards? Or you have air in your clutch line and it's not operating your slave cylinder enough.
Don't mess with my monkey...he's loaded. |
My car makes a screching noise (coming from the tranny)-too when I push the clutch pedal in first and in reverse. And my car can bearly go up a hill, like theres no power. I have a oem exedy clutch, resurfaced flywheel, oh and KA24de.
I got no clue whats the problem
well took it back, turns out hte pin holding the pivot fork broke and they used a 5speed abs drive shafe on a 5 speed non abs car..
hopefully should work good now
s14 kouki ka-t |
