Old 08-03-2008, 10:59 PM   #1
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Valve Cover Details...
I was just wondering about this little T on my valve cover(S13 blacktop). There is a tube from my intake to the T to my catch can...then I would think that little hose under the catch can goes to the oil pan or somthing.
The reason I bring this up is to ask what should I do if I can't fit my catch can there anymore? I just installed a new exhaust manifold and I can't fit my catch can there anymore. I've seen some people put little filters on the T...but I wanted to make sure. Should I just plug up the hose that used to go to the bottom of the catch can?
And should I just take off the tube from my intake to the T and plug that up, leaving the T open?
On a side note- Is it okay for my valve cover to leak oil kinda a lot around the head? I think it's probably just the valve cover gasket...but to double check I ask Zilvia .
Any help would be appreciated...I wanna make sure my car is safe to drive without oil shooting everywhere.
DataXUnknown is offline   Reply With Quote
Old 08-03-2008, 11:07 PM   #2
KwKouki
KwKouki's Avatar
KwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfectionKwKouki is close to perfection
Send a message via AIM to KwKouki
for now, run the front of the tee to the intake, and the back of the tee to the return tube on the engine *where your stock catch can was at*
get a aftermarket can and run the lines properly, problem solved
KwKouki is offline   Reply With Quote
