Old 08-02-2008, 03:05 AM   #1
SikxChoi
SikxChoi's Avatar
SikxChoi has a spectacular aura aboutSikxChoi has a spectacular aura aboutSikxChoi has a spectacular aura aboutSikxChoi has a spectacular aura aboutSikxChoi has a spectacular aura aboutSikxChoi has a spectacular aura about
s13 Kyb Gr2 w/Eibach Sportline Springs Question
I got a question maybe you guys can help out w/ im thinking about putting Eibach Sportline Springs w/ KYB Gr2 shocks,will it blow the shocks out at a fast rate? How reliable a set-up this is for my s13? I already have the shocks, if these springs aren't as reliable what springs do you guys recommend this is for a daily driven set-up. Thanks for your time.
SikxChoi is offline   Reply With Quote
Old 08-02-2008, 07:30 AM   #2
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
they will blow faster then say kyb agx's cause they are like stock
replacement but they are good for daily little stiffer then i thought
i had them b4 but if ur gunna endup getting coilover just save up dont waste ur money on them or buy the springs used dont make the same
mistake i did and buy everything brand new
Red Rocket
apex is offline   Reply With Quote
Old 08-02-2008, 12:28 PM   #3
norcal_black240
norcal_black240's Avatar
norcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud of
Send a message via AIM to norcal_black240 Send a message via MSN to norcal_black240
My friend been rockin gr-2 sportline setup for 2 years now. His shocks are goin out and he never seen a track day or much abuse. Unless you are just lookin for a cheap quick temporary setup then its coo. But like other have said just save for coilovers. Godspeed or megan its better than rockin a gr-2. If you can afford it go koni yellow/ground control
norcal_black240 is offline   Reply With Quote
Old 08-02-2008, 12:48 PM   #4
!Zar!
!Zar!'s Avatar
gr-2 is an oem like replacement.
Don't buy them thinking they are any better than stock.
AGX's are the sportier version of them.
Or get koni yellows.
Fyi, just because the car isn't tracked doesn't mean the car isn't seeing abuse.
Everyday stop and go driving is worse than tracking a car mechanically wise.
The mean streets are harsh, you dig it?
Old 08-02-2008, 03:15 PM   #5
SikxChoi
SikxChoi's Avatar
s13
is it just better to use the KYB GR 2 with stock springs?
Old 08-02-2008, 03:24 PM   #6
JDM671
JDM671's Avatar
Trader Rating: (37)
JDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to JDM671
I had that same set up. Nothing wrong with them. They lasted for 2 years or so. They were in good condition still. So I sold them. lol
Touke <3
JDM671 is offline   Reply With Quote
Old 08-02-2008, 05:50 PM   #7
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Listen to this d00d. Save up and get some yellows.
flip3d is offline   Reply With Quote
Old 08-04-2008, 07:03 AM   #8
Brentbohn
Brentbohn's Avatar
Brentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choices
i have gr2 and sportlines in my s14 and have no problems at all.. drive it like i stole it daily.... in the rear i have agx on setting 8
Brentbohn is offline   Reply With Quote
Old 08-04-2008, 07:07 AM   #9
ZX88
ZX88's Avatar
i had this set up on my s13 about 2 years ago. it sucked the rear gr2s blew within a year of installing them from daily driving! stay away from that combo. i recomend you get somthing that doesnt drop the car that much if your running gr2 you might be able to get away with tien s techs or eibach pro kit.
Old 08-04-2008, 08:26 AM   #10
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
If you do end up getting these make sure you put the bump stops and new dust boots back on. You can trim the bump stops down a little too. That stuff is there for a reason and most likely the reason for the shocks failing so quickly.
-Retired
98s14inaz is offline   Reply With Quote
Old 08-04-2008, 08:37 AM   #11
ZX88
ZX88's Avatar
i replaced everything the fact is you are trying to put springs on an oem replacement that wasnt design for that kind of use. gr2 will eventally blow on anything with more than a 1.5 inch drop its only a matter of time and how good the road are near you.
Old 08-04-2008, 02:32 PM   #12
SikxChoi
SikxChoi's Avatar
s13
Should i just use my stock springs on the gr2 until i save up for coilovers or something better
Old 08-04-2008, 02:37 PM   #13
ZX88
ZX88's Avatar
i would or get stechs or a prokit. the difference between coilovers and gr2 and sportlines is really night and day.
Old 08-04-2008, 02:54 PM   #14
projectRDM
projectRDM's Avatar
The spring choice is your problem. The Sportlines lower the car more but are not as stiff, therefore giving you a little more bounce. With the added reduction of lowering the strut/shock setup can't work within it's means as well. Prokits or similar stiffer spring would be a better choice.
FORMERLY R240NA
Old 08-04-2008, 03:04 PM   #15
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
Yeah I had that for my first set up and it drops the car a little the sportlines were okay not the best obviously but My biggest regret was wasting the money and not just getting coils overs from the begging. as for the shocks like everyone has stated they are like stock no big difference maybe just a little stiffer and they took awhile before they start to sag Good luck tho =]
s13 @ fullboost is offline   Reply With Quote
Old 08-04-2008, 03:30 PM   #16
SikxChoi
SikxChoi's Avatar
s13
would the gr2 w/ Tein S tech springs be a good setup
