Old 01-02-2003, 05:33 PM   #1
Just8aV8
Just8aV8's Avatar
Just8aV8 is an unknown quantity at this point
Send a message via ICQ to Just8aV8 Send a message via AIM to Just8aV8 Send a message via Yahoo to Just8aV8
550cc injectors
i was planning on ordering either tomei or apexi 550 cc injectors, a local shop "highly suggested" a power fc, but i dont have the cash to drop on a pfc, can i use my safc to tune these injectors?
Just8aV8 is offline   Reply With Quote
Old 01-02-2003, 07:10 PM   #2
HaLo
from Canada, eh!
HaLo's Avatar
Yes, you can.
BTW, how come your S15 turbo runs 9 psi? The internal wastegate is set at 11psi... I'm running 11psi on "stock" boost setting with the S15 Turbo on a blacktop SR20DET.
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 01-02-2003, 11:34 PM   #3
Just8aV8
Just8aV8's Avatar
thanks for the response, i'm only running 9psi because when i got it tuned the stock injectors couldnt hold more then that
Old 01-03-2003, 10:31 AM   #4
HaLo
from Canada, eh!
HaLo's Avatar
I can't go lower than 11psi with my S15 Turbo because the internal wastegate is set at that amount... Did you change the wastegate?
-> HaLo
Old 01-03-2003, 10:34 AM   #5
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Stock setting for s15 is 9psi I believe. Check to see if you actuator arm is threaded. If so, the person that had the turbo before you might have set it differently.
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 01-03-2003, 11:32 AM   #6
Just8aV8
Just8aV8's Avatar
i'm ordering a hks actuator with my injectors so i'm not sure what the setting is on the stock internal
Old 01-03-2003, 01:03 PM   #7
HaLo
from Canada, eh!
HaLo's Avatar
Thanks! I'll look at it... however, I was frequently told that the stock S15 boost was 11 psi, while S14 was about 9 psi...
You might be right... Anyways, I'll do some lookin' up.
(I do know though that my car's stock boost setting is 0.78 bar... On a S15 turbo)
-> HaLo
