Old 04-07-2008, 03:10 PM   #1
stupid nissan
stupid nissan is on the path to ruinstupid nissan is on the path to ruin
j30 front hubs
will they work on the s13 i know the rear ones will just wondering about the fronts
and will i need the whole assembly cuase right now i have s14 lca megan coils and tein tie rods/w spacers and project nissan tension rods
hope i am giving enough info
thanks
stupid nissan is offline   Reply With Quote
Old 04-07-2008, 03:11 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
This has been covered! NO THEY WON'T!!! There is no bolt-on junkyard 5-lug hub solution for s-13 spindles.
Old 04-07-2008, 03:41 PM   #3
stupid nissan
THANK YOU !!!! i searched several different titles but came up with nothing so i thought i would ask
Old 04-07-2008, 03:48 PM   #4
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
^^ get ichibas...pretty cheap like 200 ish
and like racepar1 said
there arent any bolt ones from stock cars..
HS13KLS is offline   Reply With Quote
Old 08-08-2008, 10:38 PM   #5
pallnet
pallnet is making his/her stupidity well-knownpallnet is making his/her stupidity well-knownpallnet is making his/her stupidity well-knownpallnet is making his/her stupidity well-knownpallnet is making his/her stupidity well-known
Junkyard 5 lug swap....
There ARE possible JY 5 lug swaps...
S13: Rear hubs from 90's Maximas bolt right on. To fit a rotor over them you will have to put them on a lathe and shave the outer edges unless it's a big rotor. The offset is 10mm inboard but a spacer inbetween the rotor and the hub with longer studs cures this problem. For the most part the hub slips right on the S13 spindle and bolts on with no modding.
S13: I'm following what another person had done and ordered some S13 front hub bearings. The J30 front hubs will accept the bearings and the offset is perfect from what I've read. My bearings will be here in a week and the J30 hubs are waitng.
S13: S14 parts will fit the S13 to make it 5 lug. Your will need the front spindles, hubs balljoints and tierod ends from the S14.
S14: Can also use the J30 front hubs, they slip right onto the spindles once you remove the ABS reluctor and the rear seal. You will also need a spacer/washer inbetween the locking washer and the bearing. The hub sits in perfect offset to accept all brake setups out there for the S14.
SPEED IS MY DRUG OF CHOICE..LET ME DRIVE.
pallnet is offline   Reply With Quote
Old 08-08-2008, 10:46 PM   #6
racepar1
racepar1's Avatar
You revived and OLD thread for THIS! The only actual bolt-on solution is the s-14 front spindles and hubs, the rest require modification to fit. You forgot that to use the s-14 stuff on an s-13 you either need s-14 front shocks (or lower mounts for your coilovers) or you need to drill out your s-13 ones as the s-14 spindle bolts are thicker. The s-14 route is waaaaayyyyyyy too costly to even consider.
