Old 02-18-2011, 07:38 AM   #1
ll_EvOluTIoN
ll_EvOluTIoN will become famous soon enoughll_EvOluTIoN will become famous soon enoughll_EvOluTIoN will become famous soon enough
Sr20det redtop problem!!
So just did my swap and I'm having an idle problem. It seems to be idling around 1000rpm(tach nonop) then it seems to cut out for a sec. I was checking the injector pulse with test light and when the engine cuts out the injectors stop pulsing.
I checked tps adjustment an it's at .4v. I'm getting spark at all plugs. New spark plugs n gas. New stock injectors spray great. I switched between 3 ignitor chips n same prob. Switched in known good ecu. Same prob.
Any ideas of what it could be?
ll_EvOluTIoN is offline   Reply With Quote
Old 02-19-2011, 10:49 AM   #2
92dagrey
92dagrey is an unknown quantity at this point
when you say "cut out" do u mean the engine fully dies or it almost dies n then barely comes back to life? There could be some kinda short thats happening. check ecu for codes
92dagrey is offline   Reply With Quote
Old 02-19-2011, 01:36 PM   #3
ll_EvOluTIoN
No. Its like a momentary drop in idle it doesn't cut out enough to die or almost die
Old 02-19-2011, 02:30 PM   #4
92dagrey
do all the injectors cut out at the same time?
Old 02-19-2011, 03:33 PM   #5
ll_EvOluTIoN
Not sure. Ran codes n got 55. Checked tps it's .48v-3.8v wot. Maf is .8v key on engine off.
Old 02-22-2011, 01:56 AM   #6
ll_EvOluTIoN
Bump!!! Still need help
Old 02-22-2011, 03:58 AM   #7
anarchyperf
anarchyperf's Avatar
anarchyperf is an unknown quantity at this point
I would try swapping out your maf first. Also sounds like you might have a loose/broken wire in the harness
www.anarchyperformance.com - Your source for 240sx Performance!
https://www.facebook.com/anarchyperformance - Like us on facebook
Email: [email protected]
anarchyperf is offline   Reply With Quote
Old 02-22-2011, 07:37 AM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
How does the car drive?
Old 02-22-2011, 11:16 PM   #9
ll_EvOluTIoN
I haven't driven it yet I'm afraid it will damage the engine.
Old 02-23-2011, 09:43 PM   #10
codyace
codyace's Avatar
Trader Rating: (58)
Is the engine itself literally cutting out, or is it just sorta/kind stumbly at times?
EDIT: Can you take a video with your cell phone and post it to youtube for us?
Old 02-23-2011, 09:58 PM   #11
ll_EvOluTIoN
It's cutting out and it's consistent. It doesn't die cuz it's idling high so when it cuts out momentarily. Even if I accelerate a little higher it will still cut out the same unless I hold it at wot
Old 02-28-2011, 07:21 PM   #12
ll_EvOluTIoN
So the injectors are cutting out. I tried a new tps n it fixed the idle for 5 min n did the same. So put a new maf and the problem goes away untill I hit the throttle. Then idles bad again. Now today no matter what I do it idles bad. Here's what I got.
YouTube - Sr20det problem
Old 02-28-2011, 09:16 PM   #13
codyace
codyace's Avatar
Trader Rating: (58)
It sounds like you have a HUGE vacuum leak, or something wired incorrectly.
Old 02-28-2011, 09:33 PM   #14
slomar91
slomar91 is an unknown quantity at this point
+1 on the vacuum leak.
slomar91 is offline   Reply With Quote
Old 03-01-2011, 12:43 AM   #15
Kingtal0n
Kingtal0n's Avatar
the computer has a method for controlling fuel when the tps is untouched.
if anyone with an SR20det raises the idle without moving the tps eventually the engine hits a cut off point for fueling, its called idle fuel cut rpm. For instance if the engine is getting extra air from a vacuum leak and the idle raises to 1200rpm or so, the fuel will cut if the tps is unmoved (no one is touching the gas pedal). this is because the ecu thinks the car is in a deceleration. You want the fuel to cut when you lift your foot from the gas pedal so the engine can brake to a lower rpm.
anyways, my point is that it sounds like you have a vacuum leak, and this raises the idle to the fuel-cut RPM which causes the engine to sudden "cut out" till the rpm drops back down.
find the air leak and create a stable idle, the sudden cutting out is an actual proper mechanism within the ECU nothing is wrong with it.
Old 03-01-2011, 12:48 AM   #16
DirtyLoud
DirtyLoud is an unknown quantity at this point
+1
I'm gonna have to go with what he said!
DirtyLoud is offline   Reply With Quote
Old 03-01-2011, 10:51 AM   #17
ll_EvOluTIoN
Thanks that was a pretty awesome explanation. I'm gonna make boost leak tester n see what's up. Thanks for the input!
Old 03-01-2011, 05:44 PM   #18
ll_EvOluTIoN
So made my boost leak tester n sure enough. Intercooler is leaking hardcore!!! Thanks for the help everyone.
Old 03-01-2011, 09:49 PM   #19
codyace
codyace's Avatar
Trader Rating: (58)
Nice stuff! Awesome troubleshooting by everyone!
Old 03-01-2011, 10:48 PM   #20
anarchyperf
Good find. Let me know if you plan on ordering a new intercooler. I'll hook you up.
Old 03-17-2011, 08:24 PM   #21
ll_EvOluTIoN
Hey guys here's an update. I replaced my intercooler and checked for leaks got rid of most of them holds pressure for a min then it goes back to zero. I started it up still cutting out. Drove it just for kicks and when I was almost to my driveway it started revving on it's own so I shut it off before it went up to high. Since I tach wasn't working didn't want to permenently damage engine.
Now I put a decent tps and fresh harness. Same ecu already tried a different maf same prob. Got my rps working going forward atleast. Tach bounces off 1500 to 2000 rpm. I disconnected the iacv to see what happens wile running and nothing changed. Still cutting out
Old 03-17-2011, 08:30 PM   #22
Kemps
Kemps is an unknown quantity at this point
So the engine harness has been replaced? Change the ecu and try again, could very well be a wiring problem.
Kemps is offline   Reply With Quote
Old 03-17-2011, 08:35 PM   #23
ll_EvOluTIoN
Yea I have a brand new harness. I changed the ecu also to my Buddys ecu I know it fir sure works cuz it just came off his running car.
Should the car turn off when I disconnect the iacv?
Old 03-17-2011, 08:44 PM   #24
Kemps
Did you clean the IAC? Spray carburetor cleaner into the IAC passages and see if that works, if not then replace it and see if the idle comes back.
Old 03-17-2011, 08:48 PM   #25
ll_EvOluTIoN
Haven't done that yet. So just spray into where the 2 hose connect to right?
Old 03-17-2011, 08:50 PM   #26
Kemps
ya just to clean out all the carbon build up in it
Old 03-17-2011, 08:53 PM   #27
ll_EvOluTIoN
Thanks for the help.
You think that might have caused that random rev up as well?
Old 03-17-2011, 09:11 PM   #28
SR20Driftking4lyf
SR20Driftking4lyf's Avatar
SR20Driftking4lyf is an unknown quantity at this point
I did this one time.....smelled like hell, I would do it outside and not in a garage
SR20Driftking4lyf is offline   Reply With Quote
Old 03-17-2011, 09:17 PM   #29
Kemps
it very well could be
Old 03-21-2011, 04:50 PM   #30
ll_EvOluTIoN
So I took the iacv all the way off n super cleaned it. Same problem occurs idle bounces from 1500to 2000 n still have the injector cutt off.
Y is it that when I unplug my tps it revs up instead of getting regulated by ecu. Is the iacv used to reg the idle when tps is disconnected?
This same thing happens when I unplug coolant temp sensor.
I did a boost leak test n it holds pressure but looses it after 1min or so. I fill it to 10 psi. Does that leak seam big enough to keep causing injector cutt off?
