Old 09-12-2008, 06:48 PM   #1
illvialuver
illvialuver's Avatar
Need help from KA gurus!
Okay, I have new problems, much like the old ones. I have fuel and spark. and the cames are where they should be, but the car just turns over but does not start. the distributer is tdc as well. so i dont knwo what it could be. if anyone has any bright ideas I would appreciate it. thanks.
Old 09-12-2008, 06:51 PM   #2
timster
timster is making a name for him/her selftimster is making a name for him/her selftimster is making a name for him/her self
Out of curiosity, how's your compression?
- Tim
timster is offline   Reply With Quote
Old 09-12-2008, 06:53 PM   #3
illvialuver
should be fine. I got the motor from a running car and just replaced te head gasket, and other gaskets and hoses and lines.
Old 09-12-2008, 10:10 PM   #4
ericcastro
ericcastro's Avatar
fuel pump working well??
will it stumble? (vacumm/MAF maybe?)
plug wires in right order?
moved the dizzy around to make sure its set right?
thats all i can think of.
intake looks like all the hoses are connected?
Old 09-12-2008, 10:21 PM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
i know you said the cams are where they are supposed to be
(pointing away from each other iirc)
but it sounds to me like you're 180 degrees off tdc.
no help I know but I've gone through this a few times and it sounds familiar.
Old 09-12-2008, 10:29 PM   #6
nismo240sxdrifter
nismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choices
I had this problem when I swapped my KA into my s13, if its an s13 just make sure that all of the wires are plugged in securely to your coil, then double check and make sure agian, on of mine was broked so I just braced it to the connector with a good old zip tie.
nismo240sxdrifter is offline   Reply With Quote
Old 09-12-2008, 10:35 PM   #7
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
make sure all your vaccuum hoses are connected and in the right spots...
smurfgcr is offline   Reply With Quote
Old 09-12-2008, 10:35 PM   #8
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
wierd of you to say that cause my bro had the same problem..is your fuel pump working?? sounds stupid to ask but thats what happen to my bros turn the key to the 2nd position befor cranking can you hear fuel pump prime if not thats your problem pm me if you find something new
S-Nation S13 is offline   Reply With Quote
Old 09-13-2008, 09:09 AM   #9
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Sounds like you distributor is off. Just advance the hell out of it so the car will start and stay running and back it down to 20* btdc once the car warms up.
-Retired
98s14inaz is offline   Reply With Quote
