Old 08-23-2008, 12:23 PM   #1
unwtdhero
unwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-known
KA Compression tester line stuck in cylinder 1.
So last night on my way home from work, my car started to overheat due to air in the coolant lines. So once i got home i pulled in the shop to check my compression in case the HG is blown. Well once i put the compression tester line in, it got stuck. So i removed the valve cover and pulled and twisted the line but no luck, something has to give.... Any ideas? i searched and found one guy that this also happened to and he mentioned in the thread that he used 3M electrical tape. Doesn't make sense to me.
unwtdhero is offline   Reply With Quote
Old 08-23-2008, 10:21 PM   #2
Andrew Bohan
whhhhaatt??
it should only take as much force to remove as it took to screw it in.
how the heck did that happen?
Old 08-23-2008, 10:37 PM   #3
FRpilot
FRpilot's Avatar
overtightened?
FRpilot is offline   Reply With Quote
Old 08-23-2008, 11:13 PM   #4
P_856
P_856's Avatar
P_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really nice
this happened to me once i took a screw driver and put a shitload of electrical tape on the end sticky side out and used that to turn it and pulled it out
P_856 is offline   Reply With Quote
Old 08-24-2008, 01:06 PM   #5
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
haha, happened to me once. i unscrewed it and the piece that goes into the spark plug hole got stuck there
i ended up using the knife edge of a tire iron..
1slowS13 is offline   Reply With Quote
Old 08-24-2008, 03:25 PM   #6
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
you should have use one of these
but since you didn't i suggest you
drill 2 hole in it and stick a long pair
of needle nose pliers
PM ME if you have any questions
i can take pix if you need
-los
los_inc is offline   Reply With Quote
Old 08-24-2008, 09:38 PM   #7
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
ok i had this happen a while back. here is what you do. cut it flush with the top of head.. stick a piece of copper down the center into your combustion chamber. be careful not to put it in too far. now take your plug and shove it into the hose. make sure its touching the copper wire you shoved in there. now take your coil and put it right on the plug. dont worry about not being able to bolt down the coil, the hose will hold it in place. you will be mint.
just kidding, seriously just turn it harder, it will come out.
aNskY is offline   Reply With Quote
Old 08-25-2008, 11:33 AM   #8
Fractur3
Fractur3's Avatar
Fractur3 is on the path to ruinFractur3 is on the path to ruin
never had this happen to me before but would a strap wrench work?
Fractur3 is offline   Reply With Quote
Old 08-27-2008, 12:31 PM   #9
unwtdhero
I got it out, and AnSky you're a genious. Worked like a charm! haha, no but for an hour i turned and twisted the line it eventually broke loose!
Old 08-27-2008, 11:00 PM   #10
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
yea...you screwed it into a hot head
then the hot head cooled with it still screwed in....
see where im goin with this
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 08-28-2008, 08:37 AM   #11
unwtdhero
Haa yeah i realize that now. But it's alll good
Old 08-28-2008, 08:45 AM   #12
TqMnster
TqMnster is making a name for him/her selfTqMnster is making a name for him/her self
Funny stuff lol Glad you got it out though
TqMnster is offline   Reply With Quote
Old 08-28-2008, 09:49 AM   #13
smelly240
smelly240's Avatar
I'm gonna remove some red for you learning what not to do :P
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 08-28-2008, 10:24 AM   #14
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
this happened to me yesterday.
i used a 17mm deep socket, extension and a ratchet...easy peasy
markyboi is offline   Reply With Quote
