Old 01-15-2003, 09:29 PM   #1
TheTimanator
TheTimanator's Avatar
SR swap in 89, what to do about the guages?
I'm starting to get all the little bits and peices together since my engine is shipping sometime this week and I forgot that the tach won't work since I have an 89. So my question is (I assume that the 91-94 gauges fit) if I get the newer gauge set, can I change the mileage somehow? or would it be better to just buy an after market tach? Thanks
Old 01-15-2003, 09:36 PM   #2
AKADriver
AKADriver's Avatar
Here's what you can do...
You can just change the tach.
Take your original cluster out, remove the original tach, and swap a tach from a JDM or '91-'94 US cluster into it. That way, you keep the original speedometer and odometer.
Old 01-16-2003, 09:13 AM   #3
HaLo
from Canada, eh!
HaLo's Avatar
if you are in need of a JDM 9000rpm tach, I'll be having one spare within the week. Let me know.
I'll also be having a 91-94 Tach available.
(clusters too if you wish)
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 01-16-2003, 09:19 AM   #4
wren240sx
wren240sx is an unknown quantity at this point
how much are you guys paying for the sr swaps all together?
1991 240sx se
red w/ big #$* dent in it!!
5 speed
injen cai
apexi n1 dual
unorthadox pulley set
oh yeah and a blown motor
wren240sx is offline   Reply With Quote
Old 01-16-2003, 09:46 AM   #5
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
Something that should be noted FOREVER:
The tach in the HUD cluster is SMALLER than the tach in the analog cluster. I have a 91 DOHC tach in my 89 w/HUD. To install it, I first of all had to trim a weird thingie that was sticking out all funky-like. Then once I got it to fit, you can JUST BARELY see the tick marks from around the HUD trim bezel. It works fine, though. All I'm saying is BE AWARE of this.
Oh, and one more thing...the lights in the HUD cluster have these plastic "extenders" on them that actually illuminate the gauge (and the guage has a printed matrix on the back of it to even out the lighting). Thing is, the "extenders" in the HUD cluster are not lined up for the analog tach...so the night-lighting is uneven. Once again, it works...but not perfect. I will most likely sell mine eventually and get a real JDM Silvia tach.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 01-16-2003, 11:04 AM   #6
TheTimanator
Sweet. I'll take the JDM one as long as its analog. drop me an email: [email protected] What do you have to do to swicth them? I guess I should take my guages out to check it out....
Old 01-16-2003, 02:23 PM   #7
uiuc240
uiuc240's Avatar
switching is super easy. go here for pics of the job:
http://sr20.hybrids.jp/installations/instrument_cluster/index.html
Eric
2002 Mazda Protege5
Old 01-16-2003, 03:01 PM   #8
Annoying Eric
Annoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura about
Send a message via AIM to Annoying Eric
I bought a 92 guage cluster works fine.. and it looks cool when you do over 110 cause the needle hits the bottom of the cluster.....HA....
Annoying Eric is offline   Reply With Quote
Old 01-16-2003, 04:44 PM   #9
HaLo
from Canada, eh!
HaLo's Avatar
way too much!
-> HaLo
Old 01-16-2003, 06:24 PM   #10
TheTimanator
Eric
dood the link isn't working
way too much!
That is so true
Old 01-16-2003, 07:13 PM   #11
uiuc240
uiuc240's Avatar
here's the link....something got messed up in the link script. oops
gauges page
sorry about that. my bad.
Eric
2002 Mazda Protege5
Old 01-16-2003, 11:35 PM   #12
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Thumbs down Fark
uiuc240: I have a '89 that I'm doing a SR swap into now, and it has a HUD... the cluster I got is analog. So basically I'm forked and have to do that ghetto cutting job you did right?
Can't I just take the gauge cluster off of a JDM Cluster that has a HUD and use that?
BTW, the tach I have is from a JDM analog cluster, to clear up any confusion...
kazuo is offline   Reply With Quote
Old 01-17-2003, 08:24 AM   #13
uiuc240
uiuc240's Avatar
Re: Fark
Yes, that's exactly what you have to do. Unless you'd like to take the trouble of getting the SOHC gauge face off, and put it on the DOHC tach. I considered this...but it would have still had the super-lame low redline. At least the DOHC doesn't have it until 6900 rpm. Not that it matters...but at a glance, when shifting, having the higher redline is important to me. Is it to you?
Yes. That's exactly what I'm thinking of doing, just so I can have a true 7500 rpm redline. But it's extra money I just don't really care about at this point. The tach I have is working, and that's good enough for me.
Eric
2002 Mazda Protege5
