Old 09-16-2008, 09:52 AM   #1
bxjdm
bxjdm can only hope to improve
Fs 92 sileighty fully built sr/511rwhp 376tq
I am planning on moving back to newyork and i cant take car with me.
1992 nissan 240sx testing water,has about 3500 mile on the engine and all the parts it did 452rwhp w/350tq at 21lbs and 511rwhp w/376tq @ 29lbs on c16 racegas
ENGINE: SR20DET
Head
-Head Port and Polished by mazworx
-JWT S4 CAMS
-GREDDY R.A.S
-SURPERTECH SPRING & RETINERS
-APEXI 1.1MM HEAD GASKET
-TOPSPEED INTAKE MANI
-90MM Q45 THROTTLE BODY
-Head hot tanked, pressure checked, and valve job done (bylo)
Block
-Balanced crankshaft/rotating assembly
-CP PISTONS 86.5MM 8.5.1
-CROWER I-BEAM RODS
-ACL ROD & MAIN BEARINGS
-ARP HEAD STUDS & MAIN
Turbo
-GARRETT GT3076R .82
-PEAKBOOST TURBO MANI
-GREDDY RSPL INTERCOOLER
-CUSTOM 3" MANDREL DOWN PIPE
-APEX GT Spec Exhaust
-TAKA Turbo lines
Engine Management: AEM
-3.5bar Map sensor
-Ait intake temp sensor
-Tuned by glen at Brotherz racing
Fuel system
-jgy topfeed rail
-/ -8 steel braided line
-1000cc Fuel Injectors
-aeromotive A1000 Fuel Pump
-aeromotive fuel filter
Transmission
-Mazworx SRVG kit z32 transmission
-spec clutch stage 3plus
-jdm s13 vlsd 4.08 gears
-nismo transmission and engine mounts
Cooling
-Koyo Radiator
-New Nissan Thermostat
-Flex-a-Lite Dual 12in fans
Suspension
-Tein H.E 16way
-tein front camber plates
-wickid Rear upper control arms
Interior
-GReddy 60mm Boost Gauge
-GReddy 60mm Warning Water Temp Gauge
-GReddy 60mm Warning EGT Gauge
-GReddy Turbo Timer
-pioneer cd player
-Stock Steering wheel
-Stock Seats
Exterior
-silvia front end
-jdm 180sx TYPE X Taillights
-z32 brake calipers
-sportmax 002 f16x7 R16x8
The bad
needs new throwout bearing
car doesnt not have ac
no carpet no back seats
The car is solid i drive it everyday on 21lbs pump gas
10,000 OBO
bxjdm is offline
