Old 12-29-2007, 07:08 PM   #1
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
What's the most difficult car you've ever driven?
1947 Plymouth Special. Straight six, 3 on the tree, no power steering, and it weighed an ass-ton. Very complicated to get it to start, had to mess with the choke and throttle and pump the gas 1000 times and crank it forever. It also liked to pop out of gear sometimes.
Post up! =D
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 12-29-2007, 07:10 PM   #2
chitownguy
chitownguy's Avatar
chitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to allchitownguy is a name known to all
Send a message via AIM to chitownguy
My 260z because it just pure sucked can't wait to get a better motor for it, haha.
ShakotanOscar.blogspot.com
chitownguy is offline   Reply With Quote
Old 12-29-2007, 07:29 PM   #3
ThatGuy
Admin Asshole
ThatGuy's Avatar
USMC MK48 Logistics Vehicle System
I only drove one once. That was enough. Hydraulics kick the back of the back of the cab out to assist with turns. Beats the hell out of you in the front.
I wasn't supposed to be the one driving it anyway, but it still sucked.
Old 12-29-2007, 08:04 PM   #4
cdlong
i've driven an 18 wheeler and a '00 ford F350 quad cab, long bed, dually 4x4. neither were particularly difficult to drive, given enough room. that's the key though, the ford had almost the same turning radius as the stirling. i even backed the 18 wheeler into a parking loading dock on the first try.
probably the hardest was driving an '07 superduty six pack (same as above minus the dually) through the streets of Seoul. some of those streets are tight for a sedan.
cdlong is offline   Reply With Quote
Old 12-29-2007, 08:12 PM   #5
k's_silvia2.0
k's_silvia2.0's Avatar
k's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfectionk's_silvia2.0 is close to perfection
Send a message via AIM to k's_silvia2.0
My moms Mitsu minivan with 2 flat tires
k's_silvia2.0 is offline   Reply With Quote
Old 12-29-2007, 08:16 PM   #6
swiftdrift
swiftdrift's Avatar
Location: Riverside, califoolyah...Hittin the beach, lookin for ballsuckers!
swiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfectionswiftdrift is close to perfection
Send a message via AIM to swiftdrift
One of these bad boys back when i used to work for snap-on in high school through my first year of college.... had about 4 full size tool boxes loaded with tools!.... boxes alone weigh a few thousand pounds.
swiftdrift is offline   Reply With Quote
Old 12-29-2007, 08:49 PM   #7
j4d3_h4v0k
j4d3_h4v0k's Avatar
Location: a town that doesn't even warrant a dot on the map, so cal
j4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of lightj4d3_h4v0k is a glorious beacon of light
Send a message via AIM to j4d3_h4v0k
Ef civic my first attempt at buying a car thing had an unmodded sohc zc wit a stage 4 drag spec clutch (no it was never built up enough for it to have purpose) no p/s cut springs and an exhaust the size of hawaii that thing sucked so bad
Originally Posted by steve_o1989 View Post
Ever heard of Google? You should check it out sometime.
j4d3_h4v0k is offline   Reply With Quote
Old 12-29-2007, 08:53 PM   #8
muddafakka
muddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfectionmuddafakka is close to perfection
1996 Jeep Grand Cherokee. Not difficult to drive, more like awkward. I never drove an SUV before at the time...only cars. Felt kinda weird sitting up so high. I've gotten used to it since then.
muddafakka is offline   Reply With Quote
Old 12-29-2007, 09:26 PM   #9
murda-c
murda-c's Avatar
i drove a mercury sable with four blown shocks and a bad tps, and it made me nauseous.
Other than that i learned to drive stick on a car with a dogbox. We ended up not ever shifting gears though, i just learned to start going, because every time i shifted shit would grind.
Now that i think about it, who lets a noob drive on their $3000 or so transmission...haha
Old 12-29-2007, 09:31 PM   #10
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
A 1940's unibody/bed truck, 3 on the tree as well. No power steering obviously, and getting it into gear when you have no clue how to drive 3 on the tree is a biatch.
Old 12-29-2007, 09:32 PM   #11
k's_silvia2.0
^AWWW Your avatar is dope murda-c.
Old 12-29-2007, 09:43 PM   #12
LongGrain
LongGrain's Avatar
1995 GMC Jimmy
LongGrain is offline   Reply With Quote
Old 12-29-2007, 09:51 PM   #13
lil240sx95
lil240sx95's Avatar
lil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfection
Send a message via AIM to lil240sx95 Send a message via MSN to lil240sx95 Send a message via Yahoo to lil240sx95
1999 Isuzu NPR 16 ft box
lil240sx95 is offline   Reply With Quote
Old 12-29-2007, 09:54 PM   #14
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
I had to drive a huge city bus for six months to take myself and 20 of my co-workers to work everyday. It was difficult to drive but kind of fun too.
Not too bad.
Now there's nothing big that I feel I can't drive.
Old 12-29-2007, 10:00 PM   #15
eastcoastS14
eastcoastS14's Avatar
haha my first 240 that had no fuckin oil in it when the guy sold it to me(didnt check cause who really has NO oil in their car?) car basically died on me one day and the engine was just fucked after that....car wouldnt do over like 70 on the highway and the subframe was fucked and would knock around HARD every time I shifted....it would also take forever to pick up any kind of power when i stepped on the gas and sometimes wouldnt go into gear, and oh yeah I got pulled over every week for the entire summer that year.....so yeah it was a real POS lol
eastcoastS14 is offline   Reply With Quote
Old 12-29-2007, 10:02 PM   #16
s13Dr1ft
s13Dr1ft's Avatar
s13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nices13Dr1ft is just really nice
Send a message via AIM to s13Dr1ft
You win...
Mine would be in high school...early 90's range rover, 5spd, no PS, No brakes, slipping clutch and the gas pedal liked to get stuck from time to time..
Its what my boss sent me to get parts at Mercades for an S600...
1991 hatch
Drift Indy
s13Dr1ft is offline   Reply With Quote
Old 12-29-2007, 10:15 PM   #17
Antihero983
Antihero983's Avatar
hmm.....
when my first car (a 1989 olds cutlass ciera) decided that its transmission was going to slam into every gear, that sucked.....my 1991 lebaron convertable...the passenger door wouldnt stay shut, so i bungee corded it shut....the list goes on.
Old 12-29-2007, 10:22 PM   #18
murda-c
murda-c's Avatar
Haha, that reminds me of when my friend bought a car and then when he took a turn hard the low oil sloshed to the side and the oil pressure dropped to zero, causing the timing chain to jump and the engine to lock up.
Old 12-29-2007, 10:41 PM   #19
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
My sisters 2 tone volkswagen vanagon. 2 tone brown and creme. No powersteering constantly breaking down. Had to pop into neutral and rev to keep it started. Doesnt brake. doesnt go fast had to work the key in the ignition to get it to start. Drive that for a summer and you could join the swoll patrol.
tacotacotaco is offline   Reply With Quote
Old 12-29-2007, 11:22 PM   #20
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
My friend's 32 GTR with no power steering, 50/50 AWD and diffs with initial torque so high the car feels like it hops when making a U turn
or my car with a twin plate and a bad master/slave cylinder... Transmission wouldn't go in gear and it's my only car... I had to constantly turn the car off, put it in gear and then start the car only to not be able to get out of first or second gear or I'd just leave the car in third and pray I was on a downhill...
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 12-29-2007, 11:37 PM   #21
M4Rl0N
M4Rl0N's Avatar
M4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to beholdM4Rl0N is a splendid one to behold
i would say my car because everytime i get in to drive it something always goes wrong....
M4Rl0N is offline   Reply With Quote
Old 12-30-2007, 12:55 AM   #22
articdragon192
articdragon192's Avatar
Blackbird. Those who know, will know what car it is.
Old 12-30-2007, 01:10 AM   #23
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
'65 Mustang with a VERY healthy big block. 4speed. 4 wheel drum brakes (none of which worked very well). No powersteering. Super skinny rear tires. Stiff ass clutch.
Traction was nearly non-existant in this thing, and forget about trying to stop quickly... Fuck that car. It should've had big disk brakes all around and drag radials, but no, people gotta go cheap and do nothing but motor work. lol
Secondary to that would either be my old '87 Celica, which shut off constantly, was a bitch to start, and was just overall super unreliable, OR my buddy's '89 Celica AllTrac. Push starting a heavy ass 4wd car with a stiff clutch, and brakes that like to lock up on their own due to a bad brake booster is NOT fun. lol
-Kyle
Old 12-30-2007, 01:11 AM   #24
BustedS13
BustedS13's Avatar
my uncle's combine.
Old 12-30-2007, 02:41 AM   #25
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
nismo pulsar gtir Nismo beta version
http://www.importconcern.ca/stock/100175/
the os giken was so hard to get used to, once you got it moving it didn't want to stop though. such a fun car to drive
Ca_laurier is offline   Reply With Quote
Old 12-30-2007, 06:45 AM   #26
Tops*
Tops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfection
Friend's 2000 VW Jetta
Going from my car to the Jetta.
Stiff-ass clutch to a sponge feels like I have zero feel in the pedal. I just about bust my foot through the firewall every time I drive the car.
The clutch in blown out because my friend rides the clutch FOREVER (goes through a clutch every year). Pedal is super long and takes forever to disengage so my knee is past the steering wheel by the time I've shifted.
90fwhp (?) gets me nowhere.
He now wants a Z33. I wish him the best.
It's not really a difficult car to drive, I just hate driving it.
The most difficult car I've driven was my car in eight inches of snow. I couldn't get out of the driveway...
MADE IN JAPAN
Tops* is offline   Reply With Quote
Old 12-30-2007, 08:31 AM   #27
Yuri
Ghost of Zilvia past
Yuri's Avatar
This yellow Lamborghini.
So impossible to put in gear, or back up in.
I've driven many things, including farm tractors, other exotics, and large trucks, but the Murcielago takes the cake for being hard to drive. The 911 turbo is much more user friendly.
Yuri is offline   Reply With Quote
Old 12-30-2007, 09:23 AM   #28
status:one
status:one's Avatar
status:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfectionstatus:one is close to perfection
Send a message via AIM to status:one
2000 Lamborghini VT Roadster.... b/c I was shit scared... didnt wanna fuck it up.
status:one is offline   Reply With Quote
Old 12-30-2007, 10:34 AM   #29
VROOOM
VROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfectionVROOOM is close to perfection
1999 mack cement mixer. a loaded mixer can flip over in a 5 mph right hand turn
Originally Posted by Peter_North View Post
The 240sx is a budget sports coupe. The car comes stock with a tow hook.
VROOOM is offline   Reply With Quote
Old 12-30-2007, 10:37 AM   #30
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
chevy 6500 with a drive on tow bed. Had to back it onto the hoist at my dads shop. the truck was just under 3inchs skinnier then the post on the hoist.
KA-T_240 is offline   Reply With Quote
