Old 01-20-2003, 11:42 AM   #1
docrice
docrice's Avatar
docrice is an unknown quantity at this point
Send a message via AIM to docrice
Question header question
Ok, i know a lot of guys that drag race Trans Ams, Stangs, etc. and some of them use header wraps because it usually keeps the temps lower under the hood and is supposed to help exhaust flow better (?) and i was wondering if you think it would affect the 240sx, either with stock headers or aftermarket ceramic ones like hotshots, etc. thanks for the input.
Rice
docrice is offline   Reply With Quote
Old 01-20-2003, 11:59 AM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Header wrap solely keeps heat from the engine bay. The colder the intake air is, the more power you get. Also, by keeping the block cooler, you eliminate the metal expansion due to heat, which will keep closer tolerances, giving you better compression and sealing.
Header wrap will work on anything you put on it. Just don't confuse eliminating heat with keeping in heat. The heat goes somewhere, so make sure that whatever the wrap is on can deal with the absorbed heat constantly. (That is the main reason I will never wrap my turbo. The heat will stay in the turbo/wrap, and coke oil faster.)
-Jeff
Whatup?
Old 01-20-2003, 12:05 PM   #3
kandyflip445
kandyflip445's Avatar
I thought that the wrap keeping in air also help due to keeping the exhaust gases warmer and by keeping the gases hotter, keeping the velocity of the gases higher also?
Old 01-20-2003, 12:13 PM   #4
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Well. The gas law (PV=nRT) states that as temperature goes up and all else is constant, then either pressure is increased (which can't happen in an exhaust system), volume is increased (yes) or both increase (not possible). So Volume increases, but nowhere does it state that the velocity would be higher.
Also.. don't put it on your intake piping.
-Jeff
Whatup?
Old 01-20-2003, 06:07 PM   #5
docrice
docrice's Avatar
well the turbo idea makes sense, but do you think that a set of ceramic aftermarket headers (hotshots or equivalent, not that Greddy nonsense) would be alright wrapped? i know that it would have a minimal effect on the engine as far as the exhaust goes, but if i can keep underhood temps down for a few bucks then why not? i know i certainly don't care if it looks stupid...
Old 01-20-2003, 07:15 PM   #6
AKADriver
AKADriver's Avatar
It's pointless on a ceramic coated header. That's what the ceramic coating is for.
