Old 01-27-2003, 09:11 PM   #1
moose
moose's Avatar
moose is an unknown quantity at this point
What about.......
Does snow hurt any of the mods on your car? I've been told that I can't run a cold air intake in the winter, is this true? I was told not to run coilovers in the winter, is this true? I need to know what winter will do to my car, so I can work around it.
Thanks
moose is offline   Reply With Quote
Old 01-27-2003, 09:14 PM   #2
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
The cold air intake isn't a problem in snow or rain. Even the cold air extension is OK, as long as it's not submerged in water. Make sure you get a K&N filter and DEFINITELY buy the cleaner and the oil--it's made especially for repelling moisture so it doesn't go into your engine. The oil is a definite necessity.
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 01-27-2003, 09:36 PM   #3
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I'm against the oil, and all non-dry type filters. The oil gets sucked into the intake, clogs up the MAF sensor, and can accrue around the TB plate, and suck.
-Jeff
Whatup?
Old 01-27-2003, 10:29 PM   #4
moose
moose's Avatar
do you mean the moisture filter? Like the one that come on the AEM kind? lIke a bypass valve?
Old 01-27-2003, 11:01 PM   #5
AKADriver
AKADriver's Avatar
The AEM bypass valve is mostly junk. Like 96SEChick said, are you going to submerge your filter in water? no? then don't worry.
Jeff240SX, that's only a problem if you over-oil. There aren't many cone-type filters to my knowledge that don't use oil anyway... so, yeah. Everything's either a K&N-style oiled gauze, or oiled foam.
Old 01-27-2003, 11:01 PM   #6
mrmephistopheles
mrmephistopheles's Avatar
-Jeff
You know, Jeff, I've never ever had that problem. Maybe it's due to the fact that I use a K&N panel filter & not a cone.. My MAF works perfectly, and my TB is as clean as it was when I cleaned it about a year ago. I try not to soak my filter in oil.. maybe that's it.
-Kevin
Old 01-28-2003, 09:42 AM   #7
moose
moose's Avatar
would a regular filter be no good? Are the cone shaped the best for air flow, or should I have one for the summer and one for the winter?
Old 01-28-2003, 01:10 PM   #8
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Getting an Injen intake with the CAE isn't a bad idea. During the winter it may also help to remove the extension and bring the filter into the warmer engine compartment so it isn't sucking up really cold air all day and forcing the ecu to compensate with extra fuel for the added air density. Plus it would probably warm up faster at start up. The other seasons would all greatly benefit from drawing in air not heated by the engine compartment.
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
