Old 11-28-2001, 12:57 PM   #1
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
how can i correct my rear camber? i'm putting on $500 worth of tires on my car, and i need to get this taken care of. what shall i ever do? anyone know about slotted (insert correct part names here) i'm supposed to replace?
whateverjames is offline   Reply With Quote
Old 11-28-2001, 01:12 PM   #2
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
You can get offset rear camber bushings from pdm-racing if the camber is way off.  If the camber isn't off too much, the factory adjustment may be sufficient.  When I lowered my car (Eibach ProKit) my rear camber set right at -1 degree w/o any alignment...could probably get it 0 degrees if I wanted to.
LanceS13 is offline   Reply With Quote
Old 11-28-2001, 01:33 PM   #3
whateverjames
how do i do the factory adjustment? i may be able to save $55 by doing. know of a link that has instructions?
Old 11-28-2001, 01:52 PM   #4
LanceS13
AutoX Junkie
take it to an alignment shop...it's not a DIY project b/c it requires very specialized and hi-tech alignment tools.  Most shops will let you go back and watch how it's done, though.
