Off Topic Chat All non related chat goes here. |
![]() Join Date: Jul 2007
People with computer knowledge, please read.
So, It's that time again to build another computer. My budget is $1,000 to $1200 strictly for hardware only. I have about $600 alloted for a new monitor, keyboard and mouse. So, I'll spend up to $2k if need be.
The main objective for this PC will be to Run Crysis, Far Cry 2, ect damn good, and be fast as fuck on the internet, running software, windows vista 64x, ect. Any suggestions as far as motherboard, processor, ect?? |
Unless you're seriously set on this, building a new pc is not really worth it anymore. For 2K$ you can buy a complete system with specs that would rival those of a setup built for 3K$.
If you have 2K$ to spend, look up all the hardware online and add up the cost of everything you'd buy. Then go to Best Buy and compare specs and prices. |
#3 | |
#4 | |
![]() Join Date: May 2006
And you always have problems if you try to upgrade, because they use proprietary mobos, cases, sometimes even power supplies. Not saying you shouldn't look into it, just that I've always found I could do it cheaper/better/cleaner.
#5 | |
It sounds like you might be talking about Dell, I know they like to do that with their computers, or at least used to. I've never experienced that with HP or Alienware. What was really cool is that Best Buy let me open up the case in store, so I could check out the power supply, gpu, motherboard, ram, and everything. The HP I got came with a pretty sweet GeForce when I bought it around this time last year. It wasn't the absolute top of the line, but it was still pretty high up there, and to this day I can run any new game without problems, plus what's awesome is that I can watch tv on my pc, even record shows and movies, now I'm always watching cable in the corner of the screen while browsing the web, an option that the Radeon I was planning to buy didn't have. Plus I was able to get a 22" monitor instead of the 20" I was going to settle for with my budget. The case is also better with more room for expansion and a nicer cooling setup. The power supply was one of my main concerns since nowadays most gpu's require a lot of power, some even a secondary power supply, and decent power supplies aren't cheap. To my surprise the HP actually has a more powerful supply than what I was going to go with. The case and the power supply are actually where I probably saved the most money. So basically I got more than I wanted/needed, and it cost me less. That's why, from the best performance for you money standpoint, I don't really see the point of building your own pc, unless you already have some of the major components laying around, or want to be build something really crazy. Last edited by Matej; 11-09-2008 at 06:19 PM.. |
#6 | |
![]() Join Date: Jun 2008
Also, commenting on your expandability comment earlier, you mentioned that the cases aren't sealed with cement. I had an old Compaq (old) that was literally impossible to get the case open on. I went over that damn thing every way possible and could not get the case open for my life, and eventually ended up breaking the case open because the computer fried itself and I wanted the hard drive out of it to retrieve files. If I needed to get in there for some other reason and the computer was out of warranty I would be stuck with a broken case, or rebuilding the computer in a new one.
Quad core is pretty cheap now, you might as well go with that over duel core.
Buy from newegg. I helped my roomate build his computer and he went with a Asus P5Q-E mobo with a Q6600 processor. Also with a 9800 GX2 video card. And of course you could just buy the next up from him if you have the money. His computer runs games with no problems at all with video settings on max etc. I can't remember what RAM he got but last I read ddr3 is still sort of prototypey. Just do some research on the RAM. |
I would like to add that I do not agree building a PC isn't worth it anymore. It is DEFINITELY worth it. Going to Best Buy to compare specs isn't very accurate. Best Buy or anywhere else will just say "4gb of ram." They provide no brand name, timing values, etc etc. Not to mention that you get a warranty on each part(if you build one) without having to send the whole computer off or anything like that.
With any computer you buy, you have to deal with all the bullshit of everything being compatible with each other and you can't just upgrade whenever you want if you feel it is going to slow for your needs or w/e. |
#10 | |
I was going to build a system last winter, the added up cost would've been a little over 3K$. Then, before I was about to start ordering everything, I visited all of the computer stores, and decided it's not worth it to build my own, and ended up buying a system that actually by far exceeds the specs I was aiming for, while it cost over 1K$ less. And why wouldn't you be able to upgrade a bought system? I've just added a third hdd recently. It's a pc, you can upgrade every single component when you want to, it's not like they encase it in concrete to keep you from opening it up. If you're talking about voiding the warranty, most of the components that people like to upgrade usually have a separate warranty. But I can care less about warranty anyway, if something goes bad I'd rather upgrade it with a newer more powerful component, not the same part. |
#11 | |
Newegg.com - Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Processors - Desktops Newegg.com - Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Processors - Desktops Newegg.com - Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Processors - Desktops I apologize if I seem ignorant regarding specs, but I'm not sure exactly what the difference is between dual core/quad core, ect. Thanks for everybodys help so far. |
#12 | |
And about the guy saying he was making a build for 3k in the winter, buying one is better etc... That has never been the case with any computers I have seen in any of the local chain electronic stores. |
#14 |
![]() Join Date: Sep 2006
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
built my PC for $500 and it runs crisis perfect on full graphics. running a dual core amd processor 5600+ only 1 gig of ram right now.
I wouldn't spend that much money on a setup only because you will have so much extra unused memory and such it's just not needed unless your going to be having multiple development programs and games running at the same time with like 3 moniters and such. |
#15 | |
Also, stay away from AMDs right now. Intel is owning the market right now for processing and good quad cores are becoming very affordable. The Q6600 linked above is a great processor and if you feel up to it you can OC it to 3Ghz+. If you go with a Q6600, buy an aftermarket fan for it. The stock fan on these blow. If you want I can dig you up a link to the fan I bought with mine. If you build the system yourself, make sure you have compatible RAM (ddr3 is still very expensive, ddr2 is sufficient unless you want top of the line everything, which apparently you don't judging your budget for the build). Memory brands can be debated all day, just do research and make the choice yourself. I put 4Gb into mine even though I am running win XP32 (32 bit xp will only recognize ~2.5Gb of RAM, which is why I am guessing you say you want to go 64 bit. I put the extra in for future a future OS upgrade, but have put it off because...well..you know, Vista blows.). Is the software included in your budget? Make sure you don't underestimate your power supply and that it can provide enough power to your hardware. This will depend greatly on what hardware you buy and you tend to get what you pay for here. A good hard drive makes a big difference too. I'm not saying go solid state (i wish), but something higher that a 7200RPM helps a bunch with gaming. I went with a Raptor (Western Digital) which is a 10k RPM drive, 150Gb for ~$175 (looks like they have a 300Gb Raptor now for $270, which I might end up buying). I have had no problems at all and the drive is preforming as good as the day I bought it. Still quick, snappy, and consistent. Gaming computers tend to run a bit hot. make sure you buy a case with good cooling. I bought an Antec 900 which I got for sale at the time for i think 90 bucks (which is a good deal). Others will argue case selection, but the important point is to not cheap out and buy some crap case with shitty cooling potential. I got this shipped for free from NewEgg and the box is massive. Two more things: The $600 you set aside for monitor/keyboard/mouse. Do you know what size you want monitor to be? Costco is/was selling a 24" Samsung widescreen for $400 that I bought when I put my system together. It supports up to 1920x1200 (i run nothing less), had excellent reviews, and no dead pixel issues at all. With the remaining $200 you can buy a high end mouse for gaming (I bought a Lachesis, look it up) from Best Buy and a Merc Pro Gaming Keyboard (has a lefthand controller type setup on the left side of the keyboard which is great for gaming once you get used to it. All fully programmable (though I havent had to yet). Lastly, NewEgg is definately your friend here. I pieced together 90% of my system buying from NewEgg and had no issues whatsoever with them at all. They always ship extrememly fast and usually don't charge for shipping (or it's really really cheap) on most of their products. Their website also provides customer reviews, which is a big help when trying to decide on what to buy. When pricing against other website make sure you keep shipping in mind. In literally every case I checked where I found a price cheaper than NewEgg, NewEgg almost always came out cheaper after shipping, which is what really counts. Phew. Good Luck. Fell free to PM me if you need help with other things or suggestions on other parts. PS - I also disagree with buying a premade system. Its like buying a prebuilt car. You have no idea what went into it in terms of quality and shortcuts. Besides, it's better if you know how to work on your own computer. Prebuilt computers are for nubs.
#17 |
I recently (this past summer) built myself a new rig:
*Quad Core Q9300 (1333MHz FSB, 2.5GHz x4, newest shit) *MSI P35 Platinum Duo - if I did it again, I'd go P45 probably. X48 boards cost too much, and I dont care about SLI. *4GB Patriot DDR3 7-7-7-20 *750GB Seagate HDD *Radeon 4850 It kills all - spent like $900, but already had case/power supply/keyboard/mouse/etc. Shop @ Mwave because I can pick everything up.
#19 |
It's mostly used for editing video & playing games.
The case doesn't even have bolts holding the main panel on, you just twist one knob and pull the side off. Don't get me wrong, a few years ago I would've been all for building my own pc. I still love upgrading and customizing them, and if money was no object of course I'd rather build my own. |
#22 |
![]() Join Date: Nov 2008
Build a custom computer before silicon runs out. BTW i'm building a custom compaq presario. x2 ddr2 2GB patriot. 1TB hd. 2 coolmaster fans custom mounted on stock compaq case! air is also ducted through right vents closed off unneccary vents from inside. now all i need is a good video card, and sound. Then overclock! I only spent 600$ for the whole thing so far!
