Old 10-10-2008, 08:02 AM   #1
JDM_WANNAB3
JDM_WANNAB3 is an unknown quantity at this point
92 240sx auto coupe
hey everyone...new here with a probably a newb question...is there a gear difference in a auto rear end and a manual...or are they the same??? Also what would be the cheapest way to go LSD with it,(besides welding gears) since it doesnt have one. also it has the DOHC motor
JDM_WANNAB3 is offline   Reply With Quote
Old 10-10-2008, 08:24 AM   #2
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
same rear end.
cheapest way for lsd is the vlsd. but its not worth it, most prefer the big boys toys.
(kaaz, nismo, cusco....etc)
hope this helps some, contributing what i know.
chetacheese is offline   Reply With Quote
Old 10-10-2008, 08:31 AM   #3
JDM_WANNAB3
thank you...its good to know its the same.... one less step id have to do....
Old 10-10-2008, 06:30 PM   #4
krisdeezy
krisdeezy's Avatar
krisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant futurekrisdeezy has a brilliant future
Send a message via AIM to krisdeezy
yeah its the same !
but drive shafts not...
krisdeezy is offline   Reply With Quote
Old 10-11-2008, 09:38 AM   #5
JDM_WANNAB3
so will a 5 spd vlsd fit from a 95 240sx 5sp bolt up? I have 6 bolt.
Old 10-11-2008, 09:09 PM   #6
JDM_WANNAB3
bump bump bump
Old 10-11-2008, 09:23 PM   #7
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
yes but you have to use your rear cover also there is a search button
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 10-12-2008, 05:56 AM   #8
JDM_WANNAB3
sorry nothing was coming up
Old 10-12-2008, 06:27 AM   #9
JDM_WANNAB3
will i need to change the drive shaft, or does that not come till i do the 5 speed swap??
Old 10-12-2008, 06:34 AM   #10
Modrified
Modrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of lightModrified is a glorious beacon of light
auto drive shaft and 5 speed are different. you can't use your auto drive shaft when swapping to 5 speed. if that is what you are asking.
Modrified is offline   Reply With Quote
Old 10-12-2008, 06:36 AM   #11
JDM_WANNAB3
no im talking about will the vlsd bolt up to the auto drive shaft until i convert over to 5spd/sr20det....i know Ill neeed a new drive shaft when i conv auto to manual
Old 10-12-2008, 10:44 AM   #12
projectRDM
projectRDM's Avatar
Kid, please just get your head out of your ass and search. The diff is the same, just swap the rear cover. You've already been told that. Why would you think to have to swap the driveshaft if you know the diff is the same? What do you think the word 'same' means?
FORMERLY R240NA
Old 10-13-2008, 08:17 AM   #13
JDM_WANNAB3
get a life
Old 10-13-2008, 04:43 PM   #14
SqueekyClean
SqueekyClean is an unknown quantity at this point
S14 6 bolt VSLD will fit fine. (pumpkin = differential)
1. YOu will need to swap your s13 pumpkin cover onto the S14 VSLD pumpkin
2. you will also need the bolt and washer from the s14 pumpking. (the two bolt and washer that holds the pumpkin onto the chassi)
The s13 pumpking has small holes and uses bolt with no washers.
The s14 pumpking has a larger hole in the mounting tab and has washers and rubber bushing I remember.
Just use get the S14 VSLD pumpkin, and all the nuts and bolts and you should be okay.
6 axle bolts x both axles = 12 bolts set
4 driveshaft bolts= 4 bolts set
2 nuts / 2 mounting bolts = 2 nuts and 2 bolts.
Cost: $100-200 for a VSLD great for daily driving and aspirated driving. For the track and more performance, then LSD for sure.
ALSO: if you can find a Super Hicas s13 oem VLSD it's the same. R200
SqueekyClean is offline   Reply With Quote
Old 10-15-2008, 08:47 AM   #15
JDM_WANNAB3
I can find the r200, for like 350 shipped.
Old 10-15-2008, 08:48 AM   #16
JDM_WANNAB3
thanks for the help squeeky
