Old 01-28-2003, 11:56 PM   #1
akiraintegra06
akiraintegra06 is an unknown quantity at this point
Send a message via AIM to akiraintegra06
s13 How to tell a stock open diff from a lsd
Im new to the 240 game and was just wondering how you tell if the car(1990 240sx) has a lsd or not just by looking at the diff? Are there markings on the housing that show its an lsd?
I found a parts car, but they guy doesnt know too much about the car(lien sale). I have already taken the motor/trans,inside wire harness, motor wire harness, ecu, ac/vent controls, dash, power win/locks/mirrors, fenders and the whole front end.
An lsd would top it off for the amazing price I paid for all this junk.
any help would be apprieciated. by the way if the price is right I will sell these parts except for the motor and trans.
thanks
Scott
akiraintegra06 is offline   Reply With Quote
Old 01-29-2003, 12:25 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
LSD housing has large cooling fins on the bottom.
Old 01-29-2003, 12:30 AM   #3
Jeff240sx
I hate you too...
Jeff240sx's Avatar
There should also be an orange sticker on the housing telling you to fill with silicon differential fluid only.
You could also jack up the car and turn the rear wheel. If there is resistance on it after a couple turns, if not immediatly, it's limited slip.
-Jeff
Whatup?
Old 01-29-2003, 06:03 AM   #4
drift_newbie
drift_newbie is an unknown quantity at this point
also
On my s13, the stock open diff would turn the tires in opposite directions if you had it in gear with no load on the back end, but the r200v, (lsd,) turns both in the same direction.
-ben
*Putting a smart-ass comment here is just setting yourself up to get slammed*
drift_newbie is offline   Reply With Quote
Old 01-29-2003, 07:52 AM   #5
AKADriver
AKADriver's Avatar
the 'jack it up and turn the wheel' trick could also work for a broken open diff... so I suggest not doing that.
Look for the orange sticker. By the way the sticker just says "VISCOUS LSD", nothing about the fluid. A VLSD does not require special fluid. "LSD oil" with friction modifiers is for clutch-type LSDs ONLY.
Edit: I just noticed you have a 1990. Simple way to tell if you have an LSD: YOU DON'T! They didn't sell 240SXs with VLSDs in 1990, case closed.
