Old 10-07-2008, 02:04 AM   #1
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
Adjustable FPR
I remembered that B&M make an add on kit for honda fuel pressure regulators to make is an adjustable FPR. its called the B&M command flow, I actually have one laying around here somewhere... I think i am going to try to retrofit it to a nissan FPR and see if it can be a cheaper alternative to the Nismo adjustable FPR. Hopefully it works out and we have another option available to us. If anyone has done this please chime in!
timtiminy is offline   Reply With Quote
Old 10-07-2008, 03:56 AM   #2
JohnC
JohnC's Avatar
JohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of light
dont get a nismo fpr. they are finicky. Some work good, some do not.
go Sard or other better ones. I changed from a nismo to sard as I had inconsistent fuel pressure on occasion and that is very dangerous!
JY Racing LTD.
JohnC is offline   Reply With Quote
Old 10-07-2008, 07:18 AM   #3
remi
remi's Avatar
remi is an unknown quantity at this point
Has anyone tried the one advertised by www.Poweredbymax.net Seems pretty inexpensive and I would trust their stuff over some of the "cheaper alternatives".
remi is offline   Reply With Quote
Old 10-07-2008, 08:04 AM   #4
djcobra
djcobra's Avatar
djcobra is making a name for him/her selfdjcobra is making a name for him/her selfdjcobra is making a name for him/her self
Go with SARD FPR, from what i've seen and read i'd stay away from NISMO FPR; like JohnC stated they are finicky. If you have a S14 motor, then you'll need a GReddy, SARD, or NISMO adapter. Please refer to link below: (NISMO)
Nismo FPR Fitting for SR20DET
I'd go with SARD FPR with NISMO Adapter (for S14), the SARD FPR allows you to install a pressure guage on unit it self 1/8 NPT fitting.
Steve.
djcobra is offline   Reply With Quote
Old 10-07-2008, 08:08 AM   #5
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Steve.
actually the fuel ports are 1/8NPT but the gauge port is 1/8 bspt
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 10-07-2008, 08:08 AM   #6
Z33dori
Z33dori's Avatar
does S13 SR not need the adapter for FRP? I thought i did.
Old 10-07-2008, 08:26 AM   #7
japslapsilvia
yes they do require an adapter.
Old 10-07-2008, 10:01 AM   #8
norcal_black240
norcal_black240's Avatar
norcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud of
Send a message via AIM to norcal_black240 Send a message via MSN to norcal_black240
aeromotive makes a fpr kit for our cars and those work good. Enjuku racing also sells a adapter kit to make it a bolt on affair.
norcal_black240 is offline   Reply With Quote
Old 10-07-2008, 10:03 AM   #9
Z33dori
Z33dori's Avatar
okay just wanted to make sure
thanks.
Old 10-07-2008, 11:31 PM   #10
timtiminy
timtiminy's Avatar
wow.. everyone that posted must have not read my first post. I was commenting on retrofitting a B&M command flow to fit a stock fpr to make it adjustable. I didnt say i was going to get a nismo fpr or was looking for alternatives that are already on the market. well, i guess i will try it and post results
Old 10-08-2008, 09:33 AM   #11
timtiminy
timtiminy's Avatar
I saw someone put the B&M Command Flow on a DSM fpr, so thats what got me thinking... and there is something you can do to allow relieve the pressure that build up on idle... heres the link, its for hondas but should skill be aplicable on any fpr The Old One - Energy Dynamics : Articles
Old 10-10-2008, 06:56 PM   #12
timtiminy
timtiminy's Avatar
okay so B&M sells one specifically for the eclipse turbo that will work with the nissan regulators as i have a 4g63 fpr and took measurements to compare with the nissan fpr. I will do a writeup once i buy the B&M command flow for the Eclipse.
Old 10-10-2008, 07:23 PM   #13
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
the ONLY FPR you should ever need to run
AEROMOTIVE 13109 FPR
Aeromotive 13109 - Aeromotive A1000-6 Injected Bypass Regulator - JEGS
and JEGS liquid filled PSI gauge
JEGS 41043 - JEGS Fuel Pressure Gauges - JEGS
ive seen these FPRs used in cars with 800+ whp dyno proven...its what i run in my personal car...ZERO problems
but seriously...do not waste money on a NISMO FPR guys...theyre peices of shit
Old 10-10-2008, 07:26 PM   #14
timtiminy
timtiminy's Avatar
are you serious... i am not talking about getting a nismo fpr i was simpling stating that i wanted to bring a cheaper alternative to the table that still mounts in the stock location.
Old 10-11-2008, 12:02 AM   #15
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
well i wasnt sayin you were...i just threw that in there for good measure because there are tons of kids who read this shit who think "oh that guy should just get a NISMO fpr" and dont realize theyre CRAP
anywho...i hope your idea works out for yah =D
Old 10-11-2008, 09:13 AM   #16
timtiminy
timtiminy's Avatar
I wouldnt spend the $130 they charge for a nismo fpr in the first place, thats why i am looking at this alternative... should only cost about $30 and work better then the nismo one. Thanks for the support!
Old 10-11-2008, 11:49 AM   #17
madd ocx
madd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymore
aren't there 2 different nismo fprs? one is universal and one is made for s14..
madd ocx is offline   Reply With Quote
Old 10-12-2008, 12:55 AM   #18
timtiminy
timtiminy's Avatar
yeah, there is a nismo fpr that goes directly onto the rail and one that you use a fitting to remote mount, if you are going to remote mount i would suggest something other than the nismo fpr, but this thread is about an alternative to the direct mount nismo fpr that is cheaper and direct mount and adjustable.
Old 10-12-2008, 06:39 PM   #19
madd ocx
i know your thread is for an alternative solution. i already have the one that goes directly into the rail and its fine so far.. i just asked that because maybe some people used the one thats not direct fit and have had bad results. but guess it doesn't matter, carry on!!
Old 10-23-2008, 09:36 AM   #20
MudRacer
MudRacer's Avatar
MudRacer is an unknown quantity at this point
What is so bad about the Nismo FPR? I just bought a used one for $40.
MudRacer is offline   Reply With Quote
