If you're talking about what I think you're talking about, the part that squeaks is where the throwout bearing arm rests on the little ball thingy to pivot for pushing the throwout bearing. If it's just the pedal mechanism, take some Tri-flow, or other teflon based light lubricant and squirt it. If it's inside the tranny, just lift off that rubber boot, and take some motorcycle chain lube and squirt it on the metal ball the throwout lever pivots against. MAKE SURE YOU DON'T OVERSQUIRT AND GET IT ON THE CLUTCH. A little dab'll do ya.
