Old 06-08-2013, 01:24 PM   #1
babyjesus
babyjesus's Avatar
babyjesus is an unknown quantity at this point
s14 crank angle sensor location/template..help a brotha out
So i'm getting ready to do the manual trans swap on my s14. I'm using and s13 trans and plan on drilling the bell housing to fit the s14 CAS..my only problem is being able to drill the hole in the exact spot. I like to think i'm pretty good at search but have found no success on the subject. I've seen people make templates but non supply measurements. If one of you has a s14 trans lying around would you help a fellow zilvian out my posting the measurements of the cas holes?
the stuff i've found looks like this:
any help would be appreciated...I understand that the holes don't need to be super spot on, so even if someone provided a ball park would help me out.
thelittlebigblock.blogspot.com
babyjesus is offline   Reply With Quote
Old 06-10-2013, 09:07 AM   #2
babyjesus
babyjesus's Avatar
bump! help me someone
Old 06-14-2013, 02:04 PM   #3
babyjesus
babyjesus's Avatar
bump..still need measurements
Old 06-14-2013, 02:14 PM   #4
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Not really any template/measurement needed. Those pictures show as much as you need. As long as it is in line with the flywheel in that oem location it will work.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
