11-06-2008, 04:04 PM | #1 |
Tuning question
I need to know a few things because im broke but forced to drive my 240.
The set-up. retop, #62 FUEL- 370's, walbro255 AIR- GT28rs, KA MAF misc shiat- FMIC,3in exhaust & stock exhaust mani and an OLD school SAFC , 5 point adjustable with 30% increments... So my questions is, do you think I can get a decent A/F ratio with that and using a wideband??? ***I cant run less than 12psi due to the acuator... Only asking cuz ima broke ass and cant get the necessary parts to get it perfect right now...
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
11-06-2008, 04:33 PM | #2 |
maybe but your timing map will be fubar
might even detonate just disconnect the wastegate flapper from the actuator no boost = no issues
Need automotive work done in the antelope valley? Ask me how i can help. |
11-06-2008, 04:40 PM | #3 |
doubt it w. that alone... if you get an adjustable fpr you MIIIIGGGGGHT be able to squeeze it but its risky... you should replace the 12lb wg with one from a stock turbo..8lbs... and make sure your around 11-11.5 : 1 afr in boost to be safe.. if not...boom boom boom lol
11-06-2008, 05:00 PM | #4 |
so lets say i get some 550's, then with all the rest i should be safe... right?
11-06-2008, 05:28 PM | #5 |
You'll still be waaaay limited by your KA SOHC maf. 550's and a Z32 MAF (or N60 MAF, which is way cheaper and good to about 300hp) and you're set.
Jordan Innovations has a new web site! www.JordanInnovations.com -- All your favorite FD Pro Drifters love it, trust me -- www.JordanInnovations.com |
11-06-2008, 06:09 PM | #7 |
Just so you know, a few of us run 11-12psi on stock redtops with GT28R's... Sileighty did a dyno run and dyno'd some 255whp with A/F's in the safe zone on 12psi IIRC. So you could be good now, but my feeling is that your SOHC KA maf is your weakest link at this point. If you can do the correction using your SAFC, a N60 MAF ($20-$40) would be the best investment to get the most out of the current setup.
11-07-2008, 10:41 AM | #8 |
I have a Z32 MAF, actually two in my garage but i thought i had to change something in my ECU to allow a Z32Maf to work. I cant just slap it on can I?And if i can scrap some cash up i need to spend it wisely, hence why im asking you guys questions.
11-07-2008, 04:54 PM | #10 | |
get a spec-r turbo and a maf the spec-r is great fast spool and decent power then get injectors later and you should see close to 300whp at 17-18psi and have response but i wouldn't tune it with an afc afc = band-aid but your cut is gonna need stitches lol to be safe and have total peace of mind
