Old 02-05-2003, 09:38 AM   #1
muskrat
muskrat's Avatar
muskrat is an unknown quantity at this point
Question Welded rear
I'm looking to get a 240 soon, but trying to get a lot of information up front. I've learned a lot, but can't find anyone with an answer to this.
How would the 240sx tranny (5 speed), driveshaft, axles, and rear hold up to a welded rear diff?
Don't tell me all about a welded rear, I'm familiar with all it's ups and downs. TIA.
muskrat is offline   Reply With Quote
Old 02-05-2003, 09:44 AM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Sure you can. Someone ran a 150 shot of N2O on their 240sx, with a welded differential, and ran blistering 11.xx in the 1/4. He did, however, break tranny's. I think the best strengthener for the tranny would be cryo-treatment.
-Jeff
Whatup?
Old 02-05-2003, 09:03 PM   #3
FRpilot
FRpilot's Avatar
welded differential? does this mean the differential is welded onto the car rather than being bolted on? what's are the advantages/disadvantages of having a welded differential? someone please explain.. thank you..
FRpilot is offline   Reply With Quote
Old 02-05-2003, 10:14 PM   #4
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Welding the differential is making the rear axles connected, as opposed to bieng separated (open diff), or attached via gears, clutches or a limited slip silicon solution. The advantages of the welded axles are instaneous grip on both tires, and no maintenence. The dissadvantages are cornering, the inner tire won't have a speed difference from the outer, makeing the rear end hop around corners. That'll wear out tires, and greatly hinder handling. Welding a diff is usually a drag-car only concept.
-Jeff
Whatup?
Old 02-05-2003, 11:23 PM   #5
FRpilot
FRpilot's Avatar
thanks for the thourough explanation jeff.. looks lik i have no need to do this type of modification to my car since im going to be mostly modifying the suspension.. the strentgh of our cars..
