Old 10-25-2008, 01:37 PM   #1
j87w
j87w is an unknown quantity at this point
Anyone have a tool for checking shim's for SR head?
Im looking to rent/borrow the tool people use to determine what size of shim's I need for my valves. Anyone have one? Im waiting on this tool to finish up my build.
Thanks guys
jared
j87w is offline   Reply With Quote
Old 10-26-2008, 08:39 AM   #2
crameur
crameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nicecrameur is just really nice
feeler gauge
crameur is offline   Reply With Quote
Old 10-26-2008, 08:42 AM   #3
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
lol u beat me to it.... i was gonna say.... its called feeler gauges
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 10-26-2008, 09:20 AM   #4
kernel
Trader Rating: (28)
kernel is an unknown quantity at this point
Feedback Score: 28 reviews
You don't measure SR valve shim with feeler gauges, it's not that way.
Nissan have a specify tools to measure them. It goes into the lifter hole and has a dial gauges on it. Tools #; KV10115700
On shim side (flat shim), measure the difference between contact surfaces of rocker arm guides (shim where the rocker goes in it) and valve stem ends (Where the top of the valve is locked into the retainer).
Here's a pictures to show you, I'm not good at explaining, lol.
kernel is offline   Reply With Quote
Old 10-27-2008, 12:45 PM   #5
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
there is a guy on FreshAlloy that rents the tool for like $60, althought its not the FSM one, its a machined plate that bolts to the head that you put a dial gauge into. his user name is a2low240
aNskY is offline   Reply With Quote
Old 10-27-2008, 01:17 PM   #6
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
then it's called a dial indicator.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 10-27-2008, 08:26 PM   #7
j87w
You dont use a feeler gauge to check which shims to use. You can use a dial indicator but your dial indiciator has to be setup to sit inside the HLA so you can get accurate readings. So you have to have the correct tool. I have not found the Nissan tool to buy anywhere yet but from what I understand its around $400+.
Old 11-16-2008, 03:05 PM   #8
j87w
Still looking for this tool. Anyone have one?
Old 11-16-2008, 04:39 PM   #9
MangoDorifto
MangoDorifto's Avatar
MangoDorifto is an unknown quantity at this point
Archive this -- DIY VALVE TIP Height Tool - $30 - FreshAlloy.com Forums
This was recently posted on here. Bookmarked it so I could build one later on. Hope it helps!
MangoDorifto is offline   Reply With Quote
