1993 240sx: hicas power steering pulley has play?
the belt also squeals. I assume the pulley should not move at all other than in circular direction?
the hicas pulley is different from the regular power steering pulley. courtesy parts says they sell the driveshaft separate but the factory service manual shows the shaft and pulley as one. any insight would be appreciated. |
thanks. does anyone know if the hicas pulley comes off the shaft? because courtesy parts sells the hicas shaft for $37.
if bearing is gone, should i just replace the pump? i can get new one shipped for about $130. |
![]() Join Date: Nov 2007
you may be able to find another zilvia member that has one. start a want to buy thread for one.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
thanks. Courtesy parts says the shaft for hicas pump no longer available.
"I had to call Nissan on this. They could not verify if the pulley comes with that shaft. The shaft is no longer available. The only way to get the pulley is to buy the entire pump.. but it is no longer available from Nissan." |
