Old 12-01-2008, 11:06 AM   #1
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
BNR32 brakes on s13
Anybody have firsthand experience with a full BNR32 GTR brake setup on a
s13?
I am having trouble with my rears right now.
something seems wrong. with the rotor and caliper on, they will turn slightly and then abruptly stop.
when i bolt the wheel on, i can't even turn it at all.
e brake isn't hooked up yet.
drum shoes dont appear to be too tight against the rotor.
pads dont seem to be too tight.
http://bhworld.wordpress.com/
Old 12-01-2008, 11:09 AM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Loosen up the adjustment on the e-brake drum, it is probably too tight and is sticking.
Old 12-01-2008, 11:23 AM   #3
Brian
Brian's Avatar
Trader Rating: (54)
Yeah, that is what I thought.
The e brake cable isn't even hooked up yet.
I loosened up one side so far (the shoes). I could easily slide the rotor on. Still had them problem...
Old 12-01-2008, 11:28 AM   #4
Dousan_PG
Dousan_PG's Avatar
yeah thats not the problem we tried that racepar
i was thinking
maybe the skyline hat size on the rotor was tad smaller then z32 rotor??
Aaron
Pink GodziRa
Old 12-01-2008, 12:00 PM   #5
projectRDM
projectRDM's Avatar
Not supposed to be. Z32, Q45, J30, R32, BNR32, R33 should all have the same size rear rotor. What upright is being used, stock?
FORMERLY R240NA
Old 12-01-2008, 12:03 PM   #6
DOOK
DOOK's Avatar
had a similar problem with a jeep one time... turned out I had the wrong bearing assembly... trying to take apart the rear in my mind... don't think that could be the problem though
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 12-01-2008, 12:04 PM   #7
Dousan_PG
Dousan_PG's Avatar
ya stock s13 upright.
i used s14 ones on mycar no problems z32 rear brakes w/ the drum and all
i havent had a chance to come over and look at brians brakes been out of town
gotta see first hand myself what isnt working right.
Aaron
Pink GodziRa
Old 12-01-2008, 12:12 PM   #8
Brian
Brian's Avatar
Trader Rating: (54)
Knowing me, it is probably some stupid problem that isn't really a problem.
Old 12-01-2008, 12:18 PM   #9
projectRDM
projectRDM's Avatar
Maybe you dropped a french fry behind the rotor?
FORMERLY R240NA
Old 12-01-2008, 12:20 PM   #10
Brian
Brian's Avatar
Trader Rating: (54)
I wish it was that easy...
I'm pretty sure I didn't leave it in gear either....
I should double check that for sure...
Old 12-01-2008, 12:25 PM   #11
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
check the pin for the e-brake, depending on if you have tabbed hubs etc. i had a similar issue where the "flange" of the pin rotated and came in contact with the drums surface.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 12-01-2008, 12:30 PM   #12
Brian
Brian's Avatar
Trader Rating: (54)
Interesting idea....
I'll look into it.
Old 12-01-2008, 12:36 PM   #13
piranhamatt
piranhamatt's Avatar
piranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud ofpiranhamatt has much to be proud of
X2. I had a similar problem when using J30 uprights with Z32 calipers/rotors.
piranhamatt is offline   Reply With Quote
Old 12-01-2008, 12:49 PM   #14
projectRDM
projectRDM's Avatar
True, that does happen. I actually cracked a rotor that way, breaking some of the inner hat material off.
FORMERLY R240NA
Old 12-01-2008, 12:56 PM   #15
Brian
Brian's Avatar
Trader Rating: (54)
shit, I don't want to break the rotor. God damn brand new GTR rotors, bro.
How did you guys fix that problem???
Old 12-01-2008, 01:03 PM   #16
japslapsilvia
thats how i figured out the problem. it was only a small piece off the "drum" portion. nothing to worrie about, i havent had an issue at all. when you tighten the nut for the pin just make sure the "flange" is straight, and dont try to tighten it more once the rotor is on.
Old 12-01-2008, 02:48 PM   #17
projectRDM
projectRDM's Avatar
Exactly. Just pull the rotor and check the see if the kingpin is lined up perfectly, some tabbed hubs don't have an alignment pin to hold it in place, once tightened it rotates a hair and hits the inner hat. Even if that's the case, it only breaks a little portion off, the one I broke was maybe a hairline piece about two inches long. We realigned it and he's been driving on the rotor for three years.
It kind of looked like rat pellets when we got the rotor off. Iron rat pellets.
FORMERLY R240NA
Old 12-01-2008, 02:51 PM   #18
Brian
Brian's Avatar
Trader Rating: (54)
Thanks BROS
Old 12-07-2008, 09:03 AM   #19
Brian
Brian's Avatar
Trader Rating: (54)
fixed it
that was exactly the problem
thanks guys
