Old 02-06-2003, 11:19 AM   #1
The Mole
The Mole's Avatar
The Mole is an unknown quantity at this point
Send a message via AIM to The Mole
Question S13 Blacktop into 96 S14
Im sure this has been asked before, and i searched with no luck
but i am doing my self with my roomate...we can tear a honda apart and wire in our sleep...so im not worried about not being able to do the wiring or the physical part...we can do that
but i sm having serious problems finding what needs to be wired to where... i have found several different locations online with all conflicting info...
so does anyone have a good direction to point me in? any help/input is greatly appreciated
TIA,
-Chris
The Mole is offline   Reply With Quote
Old 02-06-2003, 11:22 AM   #2
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
http://sr20.hybrids.jp/installations..._into_s14.html
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 02-06-2003, 11:45 AM   #3
The Mole
The Mole's Avatar
thats a 95 s14, obd I correct?
mines a 96...i've been told they're a lot different, is this true?
Old 02-06-2003, 11:49 AM   #4
Foxcolt
Foxcolt's Avatar
No, no difference. Your gonna be taking out all your emmisions stuff anyways. Unless you want to keep your carbon canister.
Once you take out the KA wiring harness you'll notice that it's exactly the same.
Nissans don't have OBD problems like some honda's do.
G'luck!
Jed
Driftec
Old 02-06-2003, 12:03 PM   #5
The Mole
The Mole's Avatar
cool, i appreciate it very much!!!
thank you for taking the time to help me and not call me a dumb newbie
also...what about a/c, is it possible to make it work with this setup?
thanks again,
chris
Old 02-06-2003, 12:13 PM   #6
Foxcolt
Foxcolt's Avatar
Here's the deal with ac. I need to do this before summer.
You have three options.
1, Keep the SR compressor and switch high and low pressure lines. The ka ones won't bolt up.
I'm also not sure whether the ECU will know to turn it on since your clip/motorset probably had that digital climate control. Which explains why the AC switch is routed through the ecu before going to the compressor itself. So you might have to hardwire the compressor. Easy since it takes 12 volts. Not sure about idle though.
2, Use KA compressor. Your gonna have to jury rig it on better than I did. I used the SR bracket and bolted up the KA compressor.... It fell while I was on the highway Fortunatly the AC lines kept it from ripping through my undercarrage.
Your gonna have to hardwire it regardless.
It'll bolt up you just have to play with it.
3, Use KA compressor and Wire the AC to run through the KA ecu. You'll have two ecu's. Just supply power and ground to the KA then wire the AC through it. Seems like the best option and probably what... I WAS gonna do till (I just realized this) I gave me ka ecu away.
Jed
Driftec
Old 02-06-2003, 12:25 PM   #7
The Mole
The Mole's Avatar
option 3 sounds the best, so let me make sure i understand correctly
1. wire motor/car for sr swap get it running correctly
2. stick ka ecu somewhere safe with supplied power and gorund
3. hook up ecu wiring to factory locations on the ka ecu (a/c components)
i understand you can get 2 bolts from ka compressor to match up with sr bracket, and ive been told to use some temp. (blue) loctite on them..
about yours falling off - my factory unit did this!!!! i was on free way and a/c lines saved it. unfourtunatly the "re-valve in compressor got broken so i baught a new one....it happend 2 times before it broke lol
thanks man
really appreciate it
-chris
Old 02-07-2003, 11:13 AM   #8
The Mole
The Mole's Avatar
Anyone else have any suggestions / input ???
-chris
Old 02-08-2003, 06:22 PM   #9
The Mole
The Mole's Avatar
Is everybody sure the wiring for the 95/96 240 is the same like on sr20.hybrid.jp ....i was talking to guy in my neck of the woods today, (Glenn) and he said $800 for wiring....cause he had to convert from OBD2 to OBD 1...??
is he right or trying to charge an arm and a leg....i would really like to do this myself, not due to mone, just cause i have always done all of my own work and enjoy it. plus the money gets applied to other parts
Old 02-08-2003, 08:21 PM   #10
4-20sx
Trader Rating: (50)
4-20sx is an unknown quantity at this point
Feedback Score: 50 reviews
Send a message via AIM to 4-20sx
alright look MOLE....go to heavythrottle.com and buy the harness there...its only 250$ and thats way cheaper than paying 800...basically that guy (GLENN) is pulling an arm and a leg and ur ======|)
"get that nacho out of my face"
4-20sx is offline   Reply With Quote
Old 02-09-2003, 12:41 AM   #11
The Mole
The Mole's Avatar
i know i can go to srswap and have them do the harness for $250, but my question was is 95/95 same? or is it different because if its the same, i have the wiring info to do it myself....wiring is no problem for me, but i just need diagrams/schematics to do so i know its right
-chris
Old 02-11-2003, 04:43 PM   #12
The Mole
The Mole's Avatar
does anyone have the obd2 wiring for a 96 240?
