Old 12-08-2008, 12:22 AM   #1
Magical Trevor
Magical Trevor's Avatar
Magical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the roughMagical Trevor is a jewel in the rough
Send a message via AIM to Magical Trevor
Power FC help
I just finished installing my Apexi PowerFC D-Jetro, I went to turn it on to make sure everything powered on, and nothing happened. I have no power to the commander, the fuel pump didn't prime and all my dash lights work.
I installed the stock ecu back in the car and the fuel pump primed perfectly and the engine cranked over. I've checked all my grounds to make sure they're properly secured. I modified the ecu wires for the IAT sensor per instructions of the PowerFC install manual. Other than that I haven't changed anything.
Am I missing anything? I can't even tell if the PFC is getting any power to it at all.
-Trevor
Magical Trevor is offline   Reply With Quote
Old 12-08-2008, 07:37 AM   #2
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
Make sure the two relays next to the ecu on the SR harness are there and good. My car had the same issue and I found that an SR harness has two relays, my car had one relay near the old ecu that you are supposed to disconnect and plug into the SR harness. I believe its the ECCS relay.
Erjay1 is offline   Reply With Quote
Old 12-08-2008, 08:45 AM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
check the apexi website. iirc there is a first-time start -up procedure that you must go through before you can start the car.
Old 12-08-2008, 12:29 PM   #4
FinkenS14
FinkenS14 is an unknown quantity at this point
Send a message via AIM to FinkenS14
Well inside the cabin we have a spot on the harness to the car that has two spots for two relays. We only have one relay. We plugged that in and still got nothing.
Switched the relay plugging it into the other one and still got nothing. Any ideas?
We also heard that the FC is picky with the power and that there is a back up power wire that needs to be connected to get the FC to work even tho the stock ECU might work without it. Does anybody got any advice on this aswell?
Ill try getting some pictures here...
FinkenS14 is offline   Reply With Quote
Old 12-08-2008, 12:51 PM   #5
FinkenS14
OK so here are the two relays, but only one connector coming from the car:
Here is where we have it grounded, along with all the other grounds for the car:
We also have this little guy hiding back behind the carpet:
We've also heard of people having this issue bcause of the ECCS because the stock ECU can work with one power wire but the PFC needs two. WE've heard of a post where i guy jumped the power on the pins and his PFC powered up, but what pins are these? Any info would be great guys, thanks!
Old 12-09-2008, 04:26 PM   #6
Magical Trevor
Ok so we got the ECCS power figured out, everything powers on. Now the problem is, we're not getting any spark to the coils. Any other power wires or something that we missed?
