Old 12-10-2008, 07:03 PM   #1
lilaznjeff
lilaznjeff's Avatar
lilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to behold
car just died outta nowhere.
1992 Nissan 240sx. S13 sr02det swap.
everything ran fine for the longest time.
we'll today, I was selling the car to my friend. and before she was going to drive out to me (1hr 20mins) i decided I was going to make sure everything ran perfectly fine so she wouldn't have any problems whatsoever.
so I'm driving the car, pulls fine, no problems and what not, I park it pop the hood, rev up and hear the bov blow off, then all of a sudden the car died?
so I'm like hmm...interesting..so I go back sit in the car, turn the key and nothing happens?
All the lights work (dome light, headlights flip up and done fine, dashlights)
the only thing that doesn't work is the: 4 little red dots on the right side of the cluster (seatbelt,oil batt etc) and when I turn the key the fuel pump doesn't prime nor does my stereo power on.
very weird...can anyone pinpoint any location by me saying this?
I've checked all the fuses from the engine bay and in the kick panel and none are blown, they all checked out fine. I pulled my ecu out, and turned the key and the light doesn't even flash.
anyone?
lilaznjeff is offline   Reply With Quote
Old 12-10-2008, 07:11 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
did you check your connection for the battery?
Slip Gypsies Blog
not sure if you realize this
Old 12-10-2008, 07:59 PM   #3
lilaznjeff
lilaznjeff's Avatar
Yea the connection is there to my battery.
the terminals are fine, and It's getting power to the battery.
Old 12-10-2008, 08:06 PM   #4
DJDANGER24
DJDANGER24's Avatar
what do you mean by its getting power TO the battery ? does it click at least when u turn the key ?
DJDANGER24 is offline   Reply With Quote
Old 12-10-2008, 09:43 PM   #5
lilaznjeff
lilaznjeff's Avatar
we'll good point^
no it doesn't click.
the headlights,dome light, cluster lights and everything else gets power from the battery
but the ignition doesn't.
does that make sense?
I have a turbo timer installed on the car, that might be the culprit?
Old 12-10-2008, 09:52 PM   #6
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
try unplugging the timer and starting the car than you'll know its not the culprit.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 12-10-2008, 09:53 PM   #7
0displacement
0displacement's Avatar
0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about
by check the connection they mean make sure its a good connection and its not corroded
0displacement is offline   Reply With Quote
Old 12-10-2008, 09:56 PM   #8
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
EGI relay?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 12-10-2008, 10:00 PM   #9
Sthrteen
Sthrteen is an unknown quantity at this point
Take it as a hint from your car...she doesn't want you to sell her.
Sthrteen is offline   Reply With Quote
Old 12-10-2008, 11:19 PM   #10
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
happens all the time. disconnect the negative terminal. tap it on the battery you will see it spark. clean the terminal. put it back on. start the car.
repda916 is offline   Reply With Quote
Old 12-10-2008, 11:30 PM   #11
silly_13
silly_13's Avatar
silly_13 will become famous soon enoughsilly_13 will become famous soon enoughsilly_13 will become famous soon enoughsilly_13 will become famous soon enough
thats right dont sell her!!! lol
silly_13 is offline   Reply With Quote
Old 12-10-2008, 11:44 PM   #12
Whycantidrive
Whycantidrive is an unknown quantity at this point
I had a problem similar to this... wasn't with a nissan tho. Try moving the wires going to the starter.
Whycantidrive is offline   Reply With Quote
Old 12-11-2008, 12:07 AM   #13
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
I would say starter problem...but since you said your fuel pump isn't priming my guesses are:
1. blown relay or fuse somewhere
2. fried ECU
hopefully it's the former. check all underhood relays and fuses related to ignition stuff. And last check the relay under the dash near the ECU.
but it's def a possibility that the turbo timer is interfering with the ignition.
as for the stereo not turning on that's jus weird. clean the terminals on ur battery to be safe
96Turbo is offline   Reply With Quote
Old 12-11-2008, 12:07 AM   #14
CIutchCollidE
CIutchCollidE's Avatar
CIutchCollidE is an unknown quantity at this point
hahah gl getting it running again... hopefully its not too big of a deal.
did you say a girl buying a sr20??
CIutchCollidE is offline   Reply With Quote
Old 12-11-2008, 11:22 AM   #15
Grimsta
Grimsta's Avatar
Grimsta is an unknown quantity at this point
Starter WTF, a starter would cause the car to die. If you have a turbo timer installed the splice in the ignition wiring could be coming loose or have a bad connection. There's definately a bad connection here. You could have possibly not had an entirely good ground causing some power wire to run hot and melt. Just time to bust out the mulitmeter and start doing alot of continuity tests
Grimsta is offline   Reply With Quote
Old 12-11-2008, 12:21 PM   #16
lilaznjeff
lilaznjeff's Avatar
THANKS GUYS.
I'm going to check everything you all said right now. I'll be back with the update, hopefully I can get this car running. It's really fucking weird the day I decided to sell it; it just fucks up!
also keep note, that when I turn the key to accesories or in the on position, the ecu light does not come on. and it's grounded properly.
also my viper alarm system doesn't work either, when I click lock or unlock it does nothing same with arm'/disarm.
I'm going to pull the entire wiring from the battery and everything brb.
Old 12-11-2008, 12:31 PM   #17
tanks13
tanks13's Avatar
tanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of light
Send a message via AIM to tanks13 Send a message via Yahoo to tanks13
battery post mabey ?
tanks13 is offline   Reply With Quote
Old 12-11-2008, 12:43 PM   #18
ReaperKouki
ReaperKouki's Avatar
ReaperKouki is an unknown quantity at this point
Send a message via AIM to ReaperKouki
just throwing this out there, had a similar thing happen to me, but you might want to double check your ignition fuse.
ReaperKouki is offline   Reply With Quote
Old 12-11-2008, 01:00 PM   #19
TravisSW
TravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfection
Send a message via AIM to TravisSW
My car has the same issue.
Check the battery, my terminals where cloose and I tightened them up and now it rarely happens.
1986 Porsche 944 Turbo (951)
1995 Nissan 240sx (S14) Miss ya.
TravisSW is offline   Reply With Quote
Old 12-11-2008, 01:19 PM   #20
nosajton
nosajton is on a distinguished road
check your ignition circuit from key hole to alarm and to turbo timer something is not energizing the ignition relays this only happens afte rinstaling a alarm or turbo timer either your alarm relays are fucked or the turbo timer is check those connections im almost sure it has to do with that.. i had a alarm go out on me and i had all the same symptoms you are describing (viper alarm too)
nosajton is offline   Reply With Quote
