Old 11-07-2008, 08:47 PM   #1
anthony326
anthony326's Avatar
anthony326 is an unknown quantity at this point
96 S14 KA24DE Problems.... HELP HELP
ok so i got my s14 and its been driving fine and suddenly im blowin the fuse that goes to my gauges the lights still work and all that just my gauges die and the fuse blows. i am also having issues starting it. it doesnt start smoothly and i also have to give it a bit of gas to get it goin. it cranks hard on first couple of cranks on cold and hot start ups. its very rought then it levels out it even shuts back off sometimes. so any leads would be great. it also has just had a fresh tune up and the IACV has been cleaned out. so im lost now. thanks for any inputs
anthony326 is offline   Reply With Quote
Old 11-07-2008, 11:12 PM   #2
projectRDM
projectRDM's Avatar
Fuse is more than likely a bad reverse switch. unplug it and try.
FORMERLY R240NA
Old 11-08-2008, 07:03 AM   #3
anthony326
anthony326's Avatar
sweet thanks i did notice one of the wires on one of my tranny plugs was messed up.
Old 11-11-2008, 09:50 PM   #4
ZipTied
ZipTied's Avatar
ZipTied is an unknown quantity at this point
For the starting problem I had the same thing. Does it die at Idle sometimes?? Check the idle adjustment screw. Idle it up a bit till it sits around 8 or 900. fixed my problem and starts fine now. Check battery connections and starter connections that sort of thing. Clean off corrosion and have them checked.
ZipTied is offline   Reply With Quote
Old 12-08-2008, 04:54 PM   #5
anthony326
anthony326's Avatar
im still having cold start problems. it turns over like a champ but takes alittle bit to start. only when its been sitting for along time. so im stumped!!!
Old 12-09-2008, 11:54 PM   #6
SLeepingPanda
SLeepingPanda's Avatar
SLeepingPanda is an unknown quantity at this point
Send a message via AIM to SLeepingPanda
Get your Battery tested and your Starter tested.
Some automotive stores like Kregan do free testing.
Simply Sophisticated...
SLeepingPanda is offline   Reply With Quote
Old 12-10-2008, 08:43 PM   #7
anthony326
anthony326's Avatar
i have a new battery like 2weeks old but i havnt had my starter checked. quick question woula bad maf cause this type of issue cause i think mine is bad i unplugged it and no change while the car is running! so thanks for the tip ill post my status later on.
