Old 10-27-2008, 08:24 PM   #1
heyitzalan
heyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant future
does it sound like my engine is knocking?
YouTube - ka24de manual swap first start up
check out the video, i think the engine is knocking on the idle. after i finish swapping the 5speed tranny. i think that i took off the distributor cap to see if it have any wear. is the timing off causing this problem?
help!
heyitzalan is offline   Reply With Quote
Old 10-27-2008, 09:07 PM   #2
Sileighty_85
Sileighty_85's Avatar
sounds like lifter tap
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-28-2008, 07:27 AM   #3
cotbu
cotbu's Avatar
sounds like timing chain to me
Old 10-28-2008, 08:53 AM   #4
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
You'd know if it was knocking. LOL...
BTW, how was the swap? Going to do the same on my S13 pretty soon.
'91 Hatch - Work in Progress
Jonnyblaze is offline   Reply With Quote
Old 10-30-2008, 02:00 PM   #5
kpc_0721
kpc_0721 is on a distinguished road
+1 sounds like they may need to be bled or replaced possibly.
Just got a motor back in my car and it sounds the same, leaning torwards the lifters making the noise since it is a slight tapping and is consistent with the revs.
kpc_0721 is offline   Reply With Quote
Old 10-30-2008, 02:29 PM   #6
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
my s13 dual cam made that same noise but it went away after a few minutes of driving. i ended up raising my idle to 800 and adjusting my timing and i haven't heard it since.
jdm538 is offline   Reply With Quote
Old 10-30-2008, 08:06 PM   #7
cotbu
cotbu's Avatar
I don't know if we're all listening to the same video but, I still hear the timing chain.
That is a common band aid fix for timing chain rattle.
Old 10-30-2008, 08:09 PM   #8
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
lifter tap
s13 @ fullboost is offline   Reply With Quote
Old 10-30-2008, 09:01 PM   #9
Sileighty_85
well OP, has your Engine had the Upper Timing chain guide removed?
If not Remove it, Its not needed
後輪駆動車1番
1986 SR86 - 200ish
Old 12-11-2008, 11:24 PM   #10
heyitzalan
for those who said, timing chain, you guys are right, i removed the timing chain guard, there are wears. i just removed it. never heard of knocking anymore. but the idle drop to 900rpm. is that normal? the tranny swap was sweet. 5speed!!! whoo
