Old 12-14-2008, 12:14 PM   #1
OBEEWON
OBEEWON's Avatar
Breaking wheel spacer studs...
Twice in two weeks I have broken studs off my spacers. The first time was in the front and I snapped off 4 studs leaving just one lug nut behind to hold my wheel on. The last time 3 broke off in the back.
The wierd thing is the spacers in the front were like a month old and the ones in the front Ive been running for two or three years. Both happened on the same side.
Question is what are the best hardened studs to use and who sells them. Ive looked around and cant really find what Im looking for.
Will they fit inside spacers, or are they only for the hubs? Not my area of expertise so some advice would be appreciated.
Old 12-14-2008, 12:21 PM   #2
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
What about an ARP stud, and weld it to the rear of the spacer, and grind it down flush?
Bigsyke is offline   Reply With Quote
Old 12-14-2008, 12:22 PM   #3
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
id like to know this too. im wondering if u can push out the shitty poop ones and put some arp's in
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 12-14-2008, 12:23 PM   #4
Bigsyke
Bigsyke's Avatar
yea but the knurl (sp) wont fit, thus a nice welding job
Old 12-14-2008, 12:24 PM   #5
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
i dont know if this will help, but a short time ago somebody posted this same problem, i think in had something to do with the spacer or wheel having movement and it broke the studs, but i can't remember if it was the unbalanced wheel or something about the spacer... if you search for something like "broken stud" or something like that its bound to show up in the search...
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 12-14-2008, 12:33 PM   #6
Jbma327
Trader Rating: (51)
Jbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really niceJbma327 is just really nice
Feedback Score: 51 reviews
Install some extended studs onto your hubs. Then press all the studs out if your spacer and just slide them onto your hubs with the extended stud.
Do you use a torque wrench to tighten you wheels?
KEEPIN IT REAL!
Jbma327 is offline   Reply With Quote
Old 12-14-2008, 12:35 PM   #7
OBEEWON
OBEEWON's Avatar
No no torque wrench.
My spacers are much too thick for just extended studs. Can you use HARDENED studs in regular aluminum spacers?
Old 12-14-2008, 12:40 PM   #8
Bigsyke
Bigsyke's Avatar
Obeewon, How cold was it outside when they broke?
Did you torque the studs when it was below 40*?
Old 12-14-2008, 01:17 PM   #9
ZX88
ZX88's Avatar
what spacers are these btw.
Old 12-14-2008, 02:47 PM   #10
cotbu
cotbu's Avatar
ObeeWon, Stop using the force to tighten your lug nuts....j/k
Old 12-14-2008, 02:53 PM   #11
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
OP: question about the studs you're talking about that you broke... are they extended studs, or are they studs that are pre-pressed in on bolt-on spacers?
imo, since you said you're running thick spacers, I'd recommend keeping oe studs and getting bolt on spacers. I wouldn't really recommend getting extended studs with slip on spacers for anything longer than 15mm, especially if they're not hubcentric. Too much stress is placed on the studs, thus probably why you're breaking them.
@adrianfromthecastle
Old 12-14-2008, 03:03 PM   #12
smelly240
smelly240's Avatar
they are bolt ons - and he should get the arp wheelbolts... i never broke one before (i ran 38mm spacers for 2 1/2 years.
they are ebays?
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 12-14-2008, 04:40 PM   #13
Bigsyke
Bigsyke's Avatar
The biggest question is how cold was it outside when it happened?
I snapped a brand new grade 10.5 bolt with 20lbs in 30*f weather.
Maybe he torqued them down durring freezing weather which kills the structural integrity of the bolt.
Old 12-14-2008, 04:47 PM   #14
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Every spacer that I have ever seen is made of aluminum and every wheelstud that I have ever seen is made of steel. How the hell are you supposed to weld steel to aluminum?
Old 12-14-2008, 04:51 PM   #15
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
That's very unlikely 30F weather can reduce the shear strength of steel that much. You have to freeze the metal down to cryo. condition to make it brittle enough to snap it off with minimum force. That's what I've learned from metallurgy.
For wheel spacers, especially the bolt-on type, you really have to torque it down with torque wrench, and it helps too if it comes with a hubcentric ring to ensure the wheel is in center.
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 12-14-2008, 05:32 PM   #16
OBEEWON
OBEEWON's Avatar
They are bolt on spacers. It wasnt very cold when I bolted them on, maybe like 40-50 deg. OE studs no problems its just the studs on the actual spacer that broke. Its just really wierd that four out of five studs broke and Im wondering what the hell was wrong.
Has anyone taken studs out of a regular aluminum spacer and put studs of thier own choice in?
If so what studs did you use and where did you get them?
Old 12-14-2008, 05:34 PM   #17
smelly240
smelly240's Avatar
i told you i did... arp's theyre effin expensive tho ob - i have 19 stock new ones u can try
Old 12-14-2008, 05:37 PM   #18
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Twice in two weeks sounds really unlikely to be a mere coincidence.
Old 12-14-2008, 05:42 PM   #19
OBEEWON
OBEEWON's Avatar
Haha, lol. How you been man.
These are some no name spacers. The ones in the back I have run for 2 plus years. The ones in the front about a month.
Old 12-14-2008, 09:05 PM   #20
Jbma327
Trader Rating: (51)
If the studs snap that easily I would not use those spacers again until you changed out all the studs, because they sound really weak the way you are describing them. You might be able to get some oem replacement studs and pressing them in. Not to sure if the pitch will line up properly. How many mm are these spacers?
KEEPIN IT REAL!
Old 12-14-2008, 09:20 PM   #21
Shift n Drift
Shift n Drift has a little shameless behavior in the past
hit out a stud from the spacer, go to a junk yard, and do some trial and error on some nissan and infinity lugs
Shift n Drift is offline   Reply With Quote
Old 12-14-2008, 10:07 PM   #22
murda-c
murda-c's Avatar
Wouldn't trial and error be bad because if you get a lug with a large knurl you'll ream out the spacer?
hardened studs, spacers, wheel studs
