Old 01-21-2009, 09:38 PM   #1
lost240soul
lost240soul's Avatar
lost240soul is on the path to ruinlost240soul is on the path to ruinlost240soul is on the path to ruin
s13 car wont start need help !!!!
it cranks but no start fuel pump is not priming..the fuse is not blown and none of the wiring was mickey mouse..i also changed the fuel pump thinking it was bad.. any ideas..
lost240soul is offline   Reply With Quote
Old 01-21-2009, 09:40 PM   #2
Sideways~S14
Sideways~S14's Avatar
Sideways~S14 is making a name for him/her selfSideways~S14 is making a name for him/her self
Send a message via AIM to Sideways~S14
Check your grounds? Have you even checked to make sure its getting spark or fuel? Need more info.
Sideways~S14 is offline   Reply With Quote
Old 01-21-2009, 09:44 PM   #3
lost240soul
yea its getting spark just no fuel.. the fuel pump doesnt turn.. i checked voltage at the pump (white/purple wire) because i was told to look there by the head tech at smoothlinez but there is no voltage there..
Old 01-21-2009, 10:15 PM   #4
lost240soul
any help ???
Old 01-21-2009, 10:30 PM   #5
slider2828
slider2828's Avatar
Fuel pump burnt out... hard wire mean volt and ground... does it turn on...
Turn and Burn!
Old 01-21-2009, 10:34 PM   #6
TeamClockworkPerformance
TeamClockworkPerformance is an unknown quantity at this point
Have you checked the fuse to the fuel pump?
TeamClockworkPerformance is offline   Reply With Quote
Old 01-21-2009, 10:36 PM   #7
lost240soul
even if the fuel pump burned out ..wouldnt it turn on since i put the new one in.. when it first died it would turn on but then i give gas and it would just die out.. like no fuel pressure.. now it just cranks
Old 01-21-2009, 10:37 PM   #8
lost240soul
yea fuel pump fuse is still good.. that was the first thing i look at...
Old 01-22-2009, 12:06 AM   #9
slider2828
slider2828's Avatar
Woops didn't read the end of the OP.... if it is new.... not much you can do.... it might be the wiring... Are you gettin power to ecu? Did you check all the fuses... fuel pump relay bad?
Turn and Burn!
Old 01-22-2009, 12:06 AM   #10
lost240soul
anymore ideas were to look ..
Old 01-22-2009, 12:31 AM   #11
JDMSTYLE
JDMSTYLE's Avatar
JDMSTYLE is an unknown quantity at this point
done any work lately to the car?
id say check your wiring and grounds.
JDMSTYLE is offline   Reply With Quote
Old 01-22-2009, 01:24 AM   #12
lost240soul
no i barley got the car running..it ran for like 2 days before it broke down again
Old 01-22-2009, 02:56 AM   #13
soon2bs13
soon2bs13's Avatar
soon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-known
Send a message via AIM to soon2bs13
could it possibly be your fuel lines?
neg repping is cool!!
soon2bs13 is offline   Reply With Quote
Old 01-22-2009, 04:00 AM   #14
lost240soul
no i highly doubt it is the fuel lines.. because the fuel pump would turn on .. in this case it doesnt even turn on..
Old 01-22-2009, 09:54 AM   #15
slider2828
slider2828's Avatar
you swap relays yet? other than that its time to take apart the loom and chase it....
Turn and Burn!
Old 01-22-2009, 12:27 PM   #16
lost240soul
thats the one thing i havent dont im gonna check that now.. its the egi pump replay right
Old 01-22-2009, 12:46 PM   #17
slider2828
slider2828's Avatar
Yup! ...................
Turn and Burn!
Old 01-22-2009, 01:32 PM   #18
lost240soul
do u need the egi one to turn the fuel pump on ..or do u need both of them to work the fuel pump
Old 01-22-2009, 01:51 PM   #19
slider2828
slider2828's Avatar
Is it it called an egi pump relay.... that is just 1 relay right? Is there 2? I dun remember, you can just grab a relay from somewhere else in the fusebox that doesn't matter. Just make sure its the same color.... which I think is green
Turn and Burn!
Old 01-22-2009, 01:53 PM   #20
lost240soul
yea there green but there is 2 one labeled EGI and the other one is EGI PUMP
Old 01-22-2009, 02:29 PM   #21
slider2828
slider2828's Avatar
I think you need egi too... Is there one you can pull out of your headlight fuse box or antyhing...
Turn and Burn!
Old 01-22-2009, 02:50 PM   #22
lost240soul
nah i just looked there is no green there..
Old 01-22-2009, 03:04 PM   #23
slider2828
slider2828's Avatar
Aww sucks... try it anyways.... I forgot what EGI was..... but EGI pump is definitely for fuel
Turn and Burn!
Old 01-22-2009, 03:09 PM   #24
lost240soul
fo sho.. im waiting on one of my friends to call me back he said he may have a relay
Old 01-22-2009, 04:54 PM   #25
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
You can pick up the relay at autozone. Color won't be the same but just make sure the diagram for the circuit is and you'll be ok. I would bet it's your relay if your fuse isn't blown but the fuel pump isn't getting power.
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
