Acceleration high pitch noise from motor
So I have this noise coming from my motor (i think since its from the engine bay) and I have no idea what it is. It occurs when I accelerate between about 2k - 3k rpm. It's a high pitched noise when I throttle but doesn't occur when it's in neutral. Noise occurs throughout all gears, but not as much when in first. I thought at first it was pinging from low octane but I've been pumping 91 for a while and no change. It's also not a vacuum leak. Any help? Thanks.
*edit* I have a ka24de |
My ka24e does the same, kind of. When I drive from 2k-3k rpm, the engine starts getting unusually loud as it approachs 3k. Similiar to your problem, it occurs in all gears. Maybe it has something to do with our compression.
![]() Join Date: Oct 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
i have the same thing and i also have a ps problem.. could it be the powersteering belt/pump going? mine is a kind of whining plus ticking noise at about 2500-3k rpms.. do you guys have ticking as well?
i have the exact same problem with my m30. vg30e.
i changed the power steering setup so it isnt that. if worse comes to worse. take a belt off one at a time on your motor, if you dont hear the noise after you take certain belts off you then found your problem. |
![]() Join Date: Oct 2004
Look at adjustments of the belts. Check for slack also look at wear of the belts as well. Maybe also clean your pulley a little as well.
Check oil levels of tranny and engine, hopefully those are all ok...
