Old 12-02-2008, 05:09 PM   #1
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
SR ACT 6-Puck Heavy Duty Clutch Kit SR20DET
used ACT clutch off SR swap. i thought it was off my KA motor but it turns out its for SR. i checked to make sure before i posted this time. it was taken out of my SR clip when i got my swap done. i got a excedy stage 3 kit with lightened flywheel so this comes complete with ACT clutch and stock flywheel.
USED ACT w/ Stock SR20DET Flywheel - $140 local pick up
more info:
ACT Heavy Duty Pressure Plates provide increased torque capacity, durability, and extended clutch life. What makes ACT Pressure Plates the highest standard in the industry? First, ACT manufacturing always begins with new units. ACT Pressure Plates are not rebuilt from worn out parts. Second, pressure is increased the right way. Altering the geometry alone is not enough. Instead, ACT engineers a stronger diaphragm. ACT diaphragms are heat-treated using an exclusive 3-stage process and the release bearing contact area is hardened to reduce wear. Third, ACT designs the pressure and release travel of the unit to be in the optimum working range. Finally, ACT assures consistency and precision by using proven assembly procedures. Every unit ACT produces is accurately balanced and tested. No guesswork, no hype, only proven engineering and calculated results for every ACT Heavy Duty.
* 6-Pad Xtreme Race Discs Absorb More Heat & Smoother Engagement
* Copper Ceramic Material Holds Approximately 28% More Torque
* Shifting is Quick & Sure Due to Rigid Design
* Solid Hub Design Highly Durable Resistant to Heat
http://squarespokes.com/
besTint is offline
