Old 02-22-2009, 09:41 PM   #1
lifewater
lifewater's Avatar
lifewater is an unknown quantity at this point
Turbo Smoking
Was at Drift Nirvana this weekend and my turbo was smoking more then usual. Originally I thought this was a possible seal issue because it only smokes (blue) when I'm idling. Once I'm on throttles it goes away.
But when I was waiting for my turn to run I noticed the turbo only smokes at idle, and while on inclines. The steeper the incline the worse the smoke. Does this indicate a different issue beyond seals that I should be looking at? Or am I just thinking too much.
Thanks :P
lifewater is offline   Reply With Quote
Old 02-22-2009, 09:47 PM   #2
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
Do you have an EGT?
SexPanda is offline   Reply With Quote
Old 02-22-2009, 11:58 PM   #3
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
it will smoke worse on inclines because theres more load on the engine. There fore more load no the turbo. So whe it's working harder, it smokes more. I don't know.
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 02-24-2009, 06:58 AM   #4
mtx450
mtx450's Avatar
mtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura about
Possible oil drain issue.
mtx450 is offline   Reply With Quote
Old 03-06-2009, 09:53 PM   #5
Jonathan Rivera
Jonathan Rivera's Avatar
Jonathan Rivera is an unknown quantity at this point
i have the same problem, when im at a stop it smokes like crazy, i installed oil seprator tank, and catch can and still smokes , it still boost 7 but not shure if turbos good.
Jonathan Rivera is offline   Reply With Quote
Old 03-06-2009, 10:20 PM   #6
snowmants
snowmants's Avatar
snowmants is an unknown quantity at this point
is the smoke coming directly from the turbo?
snowmants is offline   Reply With Quote
Old 03-07-2009, 12:31 AM   #7
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
Check to make sure rear main seals are not going out. At idle, the vaccum is higher than at open throttle, so you pressure is lower. When the engine is idling, the turbo's seals are naturally prone to heavier load, though no boost is relevant. When in throttle, your turbo is pushing that settling oil through, so of course no obvious "blue" smoke kicking or billowing out from the turbo, also check any loose bolts around the snell bolts at the turbine, not the compressor. are you having any boost creep issues when entering boost ranges?
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 03-07-2009, 10:45 AM   #8
drifterken
drifterken's Avatar
drifterken is an unknown quantity at this point
Send a message via AIM to drifterken
i dont think theres anything else beyond that.. just check ur main seals. happend to me.. so i just replaced them.. = no more smoke... =)
drifterken is offline   Reply With Quote
Old 03-09-2009, 05:02 PM   #9
mtx450
mtx450's Avatar
How was the rebuild? Have any pics of that process?
