Old 03-12-2009, 09:47 PM   #1
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
Ford T-bird t3 turbo
Bought this a while ago for a budget KA-T setup but I figure a T2 setup would be easier for me.
Turbo has some shaft play and will might need a rebuild. Rebuild kits are cheap on Ebay.
It will need new gaskets for the intake pipe and oil drain(needs a mounting bolt too).
Here are some specs I found on the turbo:
* Garrett model number: TB0322 (T3 series turbo)
* Compressor Trim: 60
* Compressor housing A/R: .60
* Turbine housing A/R: .63
* Horsepower Capabilities: ~325hp
* Internal Wastegate: Yes
* Wastegate setting: 7 psi
The wastegate flap thing is built into the outlet which I do not have so an external setup would be needed and I'm guessing that's what most people would use anyway.
$80
Local pick up only
MrMcgarrett is offline
Old 03-13-2009, 02:50 PM   #2
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
This is one ugly turbo main. Go clean it up a bit, some brake cleaner(s)'ll do it fine, come come now, i would at least want a clean old ass turbo. .. .
Bump for A (apparently) good seller however.
2/4
"GHOST"
NI_YON_Zenki is offline
Old 03-13-2009, 02:54 PM   #3
LongGrain
LongGrain's Avatar
super 60!
very nice turbo. great potential
LongGrain is offline
Old 03-14-2009, 04:14 PM   #4
MrMcgarrett
Back up to the top.
Old 03-18-2009, 12:50 AM   #5
MrMcgarrett
Last time to the top.
