Old 03-17-2009, 02:39 PM   #1
Master Chief
Master Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to all
Threw rocker arm - on the intake side ???
Hi guys.
Just had bit of bad luck - i guess having to do with my attempts to tune the Anti Lag Launch Control, or hittinig the limitter meaby earlyer that day.
Went to the dyno - seemed to be a bit low on power, so i checked the Spark Plugs - Number 1 seemed to be fouled, and looking down the bore, there was a small puddle of liquid - seemed like oil or meaby fuel - not water.
Anyway, desided to check it back home, so as i was leaving the dyno - drove for 50 seconds, and the engine stalled - upon starting i heared a clinking noise and the engine died again - only menaged to run it, holding the throttle open at above 50% - and it was working on 3 cylinders.
Towed it home.
Did some LeackDown test's on it - and it was pretty low on cylinder 1.
Took the valve cover off, and found out the ROCKER arm, on the intake side, of cylinder 1, was just sitting off the valves, on the side - held in place only on the LIFTER side, by the GREDDY LHA STOPER - ocationaly hitting the Cam lobe on the side - the two shims, just sitting on the bottom of the head.
Obviously this would explain why the car was on 3 cylinders, but i wonder what could have caused this in those 50 seconds , and wheter there was already something wrong, an i just didnt notoced it !?!?
I would have expected, antilag, to cause a brocken rocker on the EXHAUST SIDE , not a thrown rocker on the intake side.
Has this EVER happend to any of you ?
My concern is that the Leackdown showed much lower on the No.1 Cylinder, as compared to the rest.
Could be the valves are not sitted 100% in place, and need a bit of runing to sit back ? I did, remove the intake CAM, replaced everything back to its place, and playing a bit with the crack pulley - managed to raise the Leack Down result a bit - but still lower than the rest.
On the way i bled the LIFTERS on the intake side, and rechecked clerances of the shims etc.
Could something like the above, cause the valve to BEND or something ?
Here are some photos :
This is how i found it :
And the Damage (so far...)
I did some micro polish, to remove any burs, but i obviously cant remove the scratches - i just hope it will still be ok, as the ar on the side of the lobe of the cam, and most of the contact surface of the lobe with the rocker arm is still smooth.
The scratches on the retainers, shouldnt cause any problems, i think.
I have Rocker Arm stopers, as i said.
I am trying to understand why would a VALVE bend - and how - if the rocker arm moves.
The rocker arm is the only contact between the valve and the Cmashaft. If it moves out of place, than the valves would stay closed - no ? I closed, than how could the hit a piston ?
UPDATE :
About my REV limmiter, its set at 8000RPM - the thing is that although i may have reached it earlyer that day - the car seemd fine when i left the DYNO that evening - and all this actualy happed, 20 meters down the road from there.
Also, i have meassured the TIPS of the valves, using the below instrument - used for selecting the right shims to use - and they both meassure within spec.
If a valve was bend, wouldnt it be lower on the top, than a streight valve ?
Unless both valves got bent the same...
Master Chief is offline   Reply With Quote
