Old 03-15-2009, 10:59 PM   #1
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
vlsd swap
I want to know what is the easiest way to swap a na z32 vlsd into my 90 s-chassis. I have read all the tech posts from ka development to importnut and many other posts on other forums and also this forum and they never tell you exactly what to do they just give suggestions. I am going to be using NA z32 rear hubs/e-brake assembly to go 5-lug and want to know what exactly to get. BTW i am getting the axles also.
redline racer510 is offline   Reply With Quote
Old 03-16-2009, 12:39 AM   #2
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
importnuts write up seem pretty straight forward to me. you can either swap to a 6 bolt pattern VLSD output shaft to fit your stock axles, or swap to a 5 bolt axle(either JDM or J30 axle) to fit the Z32 output shaft.
Ragnarok043 is offline   Reply With Quote
Old 03-16-2009, 05:01 AM   #3
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Well, its a rather simple two-step process.
-Remove old parts.
-Install new parts.
See how simple that was?
-Kyle
Old 03-17-2009, 04:24 PM   #4
deukalionS14
deukalionS14's Avatar
deukalionS14 is an unknown quantity at this point
^^ and te smart asses appear
deukalionS14 is offline   Reply With Quote
Old 03-17-2009, 04:27 PM   #5
projectRDM
projectRDM's Avatar
As do the people who failed Middle School English.
FORMERLY R240NA
Old 03-17-2009, 04:35 PM   #6
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
well the smart ass is right...
how many years have people been doing this?
how many fucken times has this been discussed here?
in this forum?
using the same fucken set up?
remove old shit and install new... Anak ng puta, search for fucks sake, google that shit, it comes up so quick and with so many walk thrus of the same thing
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 03-17-2009, 05:33 PM   #7
redline racer510
ok i guess reading someones post is one of the common impairments in this forum lol
Old 03-17-2009, 05:49 PM   #8
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
here's my two cents.
unless you find a super low mileage z32, the vlsd is going to be poo poo and worn.
or unless you get one for cheap. but whatever.
do what sinistersentra91 is doing to his S14 and modify your subframe to accept a G35 VLSD.
clark is offline   Reply With Quote
Old 03-17-2009, 06:03 PM   #9
!Zar!
!Zar!'s Avatar
As Var said, "A VLSD is like taking a bag, filling it with shit, and shoving output shafts in it."
Don't waste your time.
Old 03-17-2009, 07:33 PM   #10
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
I'm pretty sure i posted a writeup like 5-6 years ago doing just this
edit: heres the brief write-up i did for swapping in a z32 na diff. nothing too special, pics in the post are dead links at this point...blast from the past.
http://zilvia.net/f/chat/34071-300zx...d-install.html
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 03-17-2009, 08:40 PM   #11
soreballz
soreballz's Avatar
Trader Rating: (22)
Now that I've re-read your post...
You already said you're getting the axles, the hubs, the ebrake parts (get the rotors and calipers too if you don't have them already), and the diff... Seems like you got everything you need.
I *think* NA Z32's use the same style pumpkin as the S14, so it would have those retarded big earlobes on the front mounting point, so if that's case, you'd need new bushings... Aside from that, I think you got it covered. Just slap your S13 diff cover on the Z32 pumpkin.
Oh, if you wanna use the Z's aluminum uprights, you'll need a pair of conical ball joint spacers, and either Z32 rear shocks or Z32 rear shock mount brackets for coilovers.
There. I hope this post has been more helpful than my last. If not, fuck it. lol
EDIT: The Z32 axles probably won't work. 5-bolt J30 axles will, me thinks.
-Kyle
Old 03-18-2009, 09:02 AM   #12
redline racer510
well if you shim the vlsd it will lock up without having to have excessive slip to lock up the rear end(will engage lock-up sooner)
Old 03-18-2009, 09:03 AM   #13
redline racer510
it will act like a 1.5 diff
Old 03-18-2009, 09:04 AM   #14
redline racer510
thats from rumors btw and reading some of the post on this forum
Old 03-18-2009, 10:19 AM   #15
ixfxi
Guest
Posts: n/a
do you have pics of these brackets? ive never seen them before.
Old 03-18-2009, 03:16 PM   #16
mondojackal
mondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choices
Send a message via AIM to mondojackal
Use the "edit" button.
mondojackal is offline   Reply With Quote
Old 03-18-2009, 04:04 PM   #17
soreballz
soreballz's Avatar
Trader Rating: (22)
Seriously? lol
Anywho, a quick google image search turned up this pic:
The coils on the far left and far right have Z32 lower mounts.
KTS, Stance, Megan, and several other companies sell the Z32 lower mounts separately for S13 coilovers.
-Kyle
