Old 03-07-2009, 07:45 PM   #1
pinoysurf
pinoysurf's Avatar
pinoysurf is an unknown quantity at this point
rear differential mount bushings removal
Just wondering if anyone has any tips/tricks to remove the rear diff mount bushings in the subframe.
pinoysurf is offline   Reply With Quote
Old 03-08-2009, 11:16 AM   #2
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
I removed the rubber bushing parts with a high speed drill with one of those round circle hole bits. If you get that out, than just take a hacksaw to the metal ring.. guessing you are installing solid differential bushings?
tip: just removed the whole subframe.. working underneath the car and actually installing the bushings while on the car is near dam impossible.
JRas is offline   Reply With Quote
Old 03-08-2009, 06:57 PM   #3
pinoysurf
pinoysurf's Avatar
I was afraid I would have to remove the subframe. Its never as easy as it looks. Maybe I can just lower the subframe enough to get at it and make some kind of press.
Old 03-21-2009, 11:50 AM   #4
pinoysurf
pinoysurf's Avatar
Had to remove the subframe and I just used an air hammer to get the bushings out. Took like an hour. Pain in the ass.
