![]() Join Date: May 2008
car does not turn on
my car does not turn on and i dont know why im geting fuel and i press the gas pedal and like truns off it's no power my harness all of the plugs or on by not TPS so is the TPS problem
Admin Asshole
![]() Join Date: Mar 2002
You still haven't learned to post Tech questions in Tech Talk. Thus the reason I moved this thread.
It's funny since you chose to mouth off to one of our more senior members about posting in the wrong place. Of course, you were wrong, but that didn't stop you from making yourself look even more foolish. Any of this ring a bell, kid?
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#6 | |
![]() Join Date: Sep 2006
USE A FUCKING PERIOD !!!! Jesus, we can't help you if we dont understand. Form your sentences better, and go back over what you wrote and make sure it makes sense. It sounds like you are getting fuel. It sounds like there is battery power. (radio, lights, fuel pump works). does the engine crank.(starter tries to start the engine. Car makes a noise like its trying to start?) If those things all work, then check if you are getting spark. What did you do that caused this to happen? Was your car running prior? you out of gas? (gauge broken? really, it happened to me embaressingly, and I know Kyle/soreballz remembers!)lol Get back to us with some answers and we will try and help your car get back on track. And it looks like you caught on to what the members here have said, and you are back on track ![]() |
![]() Join Date: Apr 2007
how many times can this dude spell the word "turns" wrong... So the car is getting fuel and spark, starts and shuts off?
If this is true then check your fuel pump relay, if an s14 its in ur kick panel, if s13 its under the hood. Just try swapping it out with another blue relay that goes to fans or A/c or something... You need to be more descriptive, if your just gunna post some random jibberish and expect to get an answer maybe you should rethink your post content.. like.. Car Year, Car Engine (SR/KA/RB/CA), Modifications, All symptoms (KNOWNS AND UNKNOWNS(what you havent looked at yet)), etc..
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. |
just swap sr20det red top in s13 hatch no electrics does not cut it cranks and stops it has intercooler and open downpipe the fuel pump its fine am check the relay
Is the SR from a clip?
Do you know the last time the SR ran? Maybe you need to try cranking it over a few more times, get some fuel in there. Sometimes it takes a little bit to start once a fuel injected engine runs dry. No other work was done to the engine? So compression should be there and timing should be on? |
#15 |
![]() Join Date: Aug 2008
Ahh man this give us chicago guys a bad name. Try checking your timing, check your spark pulgs and the gapping. Also multimeter your injectors or better yet pull them out and ground them to the valve cover and crank the car to see if they all are firing.
#17 |
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
Did anyone suggest to check the mass air flow sensorrrr? You know if that thing was unplugged on mine and I hit the gas, mine would just bog and be lame and die.
Tags |
240sx |
