fuel pump has me tired...
i didnt want to make a new thread about this but screw it im tired of reading and reading and checking to solve nothing...
ok i relocated my stock fuse box and relay box to the interior EVERYTHING works, but the car has been sitting a few months maybe 8-9months. now when i turn the key to the ignition the pump, which is a walbro, makes the whirring but rapidly make a gurgling sound, i check all the power and everything and it has power everywhere, when you take it out of the fuel tank it whirs regularly no problem sink it in gas and it whirs then makes a gurgling... is this a electrical problem or is the damm fuel pump going out???? i have a fuel psi gauge and it reads bout 60ish psi, then when i crank the engine it wont start... soooo... any help would be recomended i already checked per FSM the fuel pump, injectors, coilpacks, most of the harness, relay, fuse and even checked all other wiring just in case... i just want to start the car so i can have my daily again... |
i think they are correct ive always had them this way... but now you just confused me... filter one to the FPR and the other one to the return right?
![]() Join Date: Dec 2002
No. FPR is return. Filter is feed.
i really hope its no that, i would feel really dumb making a mistake as simple as that after so many years working on cars...
i think my problems are getting to me hahaha thanks guys! ill check that tomorrow =) |
just came back from starting the engine, yeah i damaged a battery and all from all the cracking thinking it was a bad electrical work i did turns out i did put the fuel hoses WRONG! oh god when i saw that i almost stuck a screwdriver in my head... changed the lines, got replacement for the battery turned on on the first start!
thanks guys! |
