![]() so the engine is installed on an s13. the engine will turn on but not smooth and will sometimes backfire, i have checked and searched online with no luck, im getting codes 11,12,13, and 21. i know what they mean but dont know were to start, are all those components bad? or is it something else... Thanks.
![]() Join Date: Oct 2004
lol... bad or your wiring sucks.... I think Jim Wolfe Technology has a list of codes for the SR.... but that is not good...
![]() Join Date: Apr 2007
You either have a fucked up harness or don't have things plugged in or fucked your own harness up. When you're doing a wiring job you only have to extend the mafs, don't have to touch the CAS wiring, ETC wiring etc... so these are what you need to do:
1. Check ECU plug for being warped 2. Open ECU check if plug leads have snapped. 3. Unplug and Replug all connections. You might also have a key grounds missing. 4. Test somone elses ECU or have your vendor replace it free of charge. 5. Have harness examined (by me ![]() 11 Crank Angle Sensor 12 Mass Air Flow Sensor 13 ECT Sensor 21 Ignition Signal Circuit
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. |
So I swapped out the ecu and now I only get the codes 12 and 13, the car is runing really rich but maybe is because of the walbro pump... But i don't think that would cause does codes... also the 02 wires are not hooked up, Just incase that would have something to do with the codes.
Oh and my rpm gauge does not work, do i need to get a doch gauge cluster? |
#6 | |
![]() Join Date: Jul 2008
Trader Rating: (41)
![]() Feedback Score: 41 reviews
Yes, DOHC Gauge Cluster. |
